chevyaddict83 39 #1 Posted November 4, 2013 I have a leak in my new to me ugly old c125. The block is dirty so I can't pinpoint it yet. Any suggestions on where to look? Sent from my SPH-L710 using Tapatalk Share this post Link to post Share on other sites
WH nut 553 #2 Posted November 4, 2013 Give it a bath and start looking Share this post Link to post Share on other sites
squonk 44,879 #3 Posted November 4, 2013 First place I would look is the oil breather Share this post Link to post Share on other sites
chevyaddict83 39 #4 Posted November 4, 2013 Give it a bath and start looking That's the plan for Saturday. I noticed it building up on part of the bottom of the motor. I'm almost thinking oil pan. I ludt like to get a head start on where to go. It runs great and the hydro works great. It just needs alit of help. Sent from my SPH-L710 using Tapatalk Share this post Link to post Share on other sites
WH nut 553 #5 Posted November 4, 2013 The breather and fuel pump are the most likely places to leak, but either way after the bath you will pin point it. Share this post Link to post Share on other sites
chevyaddict83 39 #6 Posted November 4, 2013 Thanks guys! Sent from my SPH-L710 using Tapatalk Share this post Link to post Share on other sites
Fordiesel69 271 #7 Posted November 5, 2013 -Crankshaft seals -Oil Pan -Governor shaft -Fuel Pump -Cam Cover -Point Plunger -Breather -Dipstick tube gasket Often the breather malfunctions and pushes oil out quite a few places. If the engine has a 0.10 pistion or higher, suspect the breather may be in upside down from a prior rebuild. Share this post Link to post Share on other sites
