Kevbo 81 #1 Posted November 2, 2013 Hey guys I ordered an idler pulley for the clutch assembly on my 417-A but the stens was too big? Maybe I got the wrong one...can anyone shout out the part number for the idler pulley that engages the drive belt on the 417-A? Thanks in advance, -Kevin Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #2 Posted November 2, 2013 I see flat idler Toro 7434 replaced by 112426 Stens 280-586 HD, 280-081 Std, Napa, 7-05434, Rotary 722 3-1/4" OD Noticed the parts lists include the idler for the 8-speeds # 7451 but it is a V-idler Garry Share this post Link to post Share on other sites
Kevbo 81 #3 Posted November 2, 2013 I see flat idler Toro 7434 replaced by 112426 Stens 280-586 HD, 280-081 Std, Napa, 7-05434, Rotary 722 3-1/4" OD Noticed the parts lists include the idler for the 8-speeds # 7451 but it is a V-idler Garry Thanks Garry you are the best! Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
flyovrcntry 115 #4 Posted November 3, 2013 I buy a lot of them at a farm supply,just take yours with you or measure it.They are usually a lot cheaper than a parts store,same with belts.Belts at my Rural King are a third of a parts place. Share this post Link to post Share on other sites
Jenna 6 #5 Posted August 3, 2019 Thank you for posting this picture! I found an 417-a with a snow blower and cab. My husband things I'm crazy for getting it. It was working great until the drive belt broke. I thought easy fix but holy cow and a half it was driving me crazy then I realized I had the wrong size belt 1 2 Share this post Link to post Share on other sites
953 nut 69,133 #6 Posted August 3, 2019 22 minutes ago, Jenna said: I realized I had the wrong size belt The 417 is a wonderful worker. I have had good luck with the Kevlar belts from Tractor Supply. The B-79 (5L-820) should work. Share this post Link to post Share on other sites
Jenna 6 #7 Posted August 5, 2019 How do I run the belt over the this clutch pully( not sure of the name ) Share this post Link to post Share on other sites
wallfish 20,576 #8 Posted August 5, 2019 8 minutes ago, Jenna said: How do I run the belt over the this clutch pully( not sure of the name ) Share this post Link to post Share on other sites
Jenna 6 #9 Posted August 5, 2019 Thank you thank you thank you!!! Share this post Link to post Share on other sites
