tractorbeast 27 #1 Posted November 2, 2013 Is there a thread on modifing a D series, 3 point to fit on a C-195. What is the main difference between the two models? Is the width different? Share this post Link to post Share on other sites
Shuboxlover 484 #2 Posted November 2, 2013 I always thought they were the same??? Share this post Link to post Share on other sites
tractorbeast 27 #3 Posted November 2, 2013 thers is a 3 point from a D-180 on Ebuzz for $125. But Pa., even being next door, can be quite a ways from Ohio. Pa. is a WIDE state. Share this post Link to post Share on other sites
Hodge71 691 #4 Posted November 2, 2013 The Super C 3 point and the D 3 point are exactly the same. Parts are interchangeable. Share this post Link to post Share on other sites
KC9KAS 4,745 #5 Posted November 2, 2013 For $125 I would jump on that! ROAD TRIP!!!!!! Share this post Link to post Share on other sites
ronwh 190 #6 Posted November 2, 2013 Tractorbeast, There are about 4 parts from a D 3 point that will not work on a C-195. In Toro master parts viewer, they are Part #1 lift arm assembly, #2 blocks that #1 mounts in, #5 one hydraulic hose will be too short by a couple of inches and part #11 assy upper link pivo where top link mounts. If you can pick up a D 3 point hitch for $125 I would, most run around $250 complete in good shape. I bought a C-195 with a factory 3-pt and took parts off of it, to a welding shop and had them made. D 3pts sell pretty fast, I have missed several. Good luck. Ron Share this post Link to post Share on other sites
ronwh 190 #7 Posted November 2, 2013 https://lookup3.toro...fm?xCaller=Toro Click on the above link and type in 01-19KE01 for model number and it should take you to the part drawing for a C-195 3pt. Ron Share this post Link to post Share on other sites
ronwh 190 #8 Posted November 2, 2013 The above link that I posted is not working. Would someone help me out and post the correct link to Toro Master Parts Viewer. Thanks Ron Share this post Link to post Share on other sites
Kelly 1,036 #9 Posted November 2, 2013 I put a D 3 point on my 195 and yes there are a few parts that will not work, the parts to make it fit are very hard to find I had a machine shop make some of mine, then I built the rest. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,888 #10 Posted November 2, 2013 See if this works https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro type in 01-19KE01 Garry Share this post Link to post Share on other sites
