chip61 666 #1 Posted October 29, 2013 Will the hub from a 312-8 fit my C160? The hub on the 160 is loose and keyway is torn up. I have access to a 312-8 parts tractor but I'm not sure they have the same axle diameter. The parts tractor is 90 miles away. Thanks Chip Share this post Link to post Share on other sites
doc724 927 #2 Posted October 29, 2013 I believe it will fit. Both are 1 1/8 inch axles. Check to make sure the keyway in the shaft is OK. When you install the hub, buy a new key and a new set screw and use plenty of never sieze on the axle. Share this post Link to post Share on other sites
baerpath 517 #3 Posted October 29, 2013 Take the hub down and have a new keyway put in it. Cheaper than driving 180 miles. Local shop does them for me Share this post Link to post Share on other sites
groundhog47 448 #4 Posted October 29, 2013 Not knowing your yr searching Toro the C-160 77 has axel 105875 also used on one year of 312-8, the hub on a C-160 77 lists as 105763-03 and is used on 97-2001 312-8 if that helps any. Share this post Link to post Share on other sites
richmondred01 2,393 #5 Posted October 29, 2013 Chip, I'm pretty sure I have one off a 300 or 400 series. Let me check and I will pm you. Share this post Link to post Share on other sites
chip61 666 #6 Posted October 30, 2013 Thanks for the replies! If you have one off a 300 or 400 that will save me trying to get the hub off that 312-8. It's been outside for years! Share this post Link to post Share on other sites
baerpath 517 #7 Posted October 30, 2013 Check axle size first, most 312's had 1 inch axles amd C160's used 1 1/8 axles. Share this post Link to post Share on other sites
richmondred01 2,393 #8 Posted October 30, 2013 I have a nice one part 105762. 1 1/8 axle so check to see if yours is correct. Share this post Link to post Share on other sites
