chip61
Axle hub
chip61
Will the hub from a 312-8 fit my C160? The hub on the 160 is loose and keyway is torn up. I have access to a 312-8 parts tractor but I'm not sure they have the same axle diameter. The parts tractor is 90 miles away.
Thanks
Chip
doc724
I believe it will fit.  Both are 1 1/8 inch axles.  Check to make sure the keyway in the shaft is OK.  When you install the hub, buy a new key and a new set screw and use plenty of never sieze on the axle.
baerpath
Take the hub down and have a new keyway put in it.  Cheaper than driving 180 miles. Local shop does them for me
groundhog47
Not knowing your yr searching Toro the C-160 77 has axel 105875 also used on one year of 312-8, the hub on a C-160 77 lists as 105763-03 and is used on 97-2001 312-8 if that helps any.
richmondred01
Chip, I'm pretty sure I have one off a 300 or 400 series. Let me check and I will pm you.
chip61
Thanks for the replies! If you have one off a 300 or 400 that will save me trying to get the hub off that 312-8. It's been outside for years!
baerpath
Check axle size first, most 312's had 1 inch axles amd C160's used 1 1/8 axles.
richmondred01
I have a nice one part 105762. 1 1/8 axle so check to see if yours is correct.
