groundhog47 445 #1 Posted October 29, 2013 Discussing my K-241 with magneto ignition, rope start or a similar configuration has anyone converted to battery ignition. Obviously a battery and coil would be required and of course if chargig battery, a gen stator and associated flywheel should be needed. Is there a slight variation in firing time with magneto as to battery, or is all same with exception of power (battery) source to coil/points. Searched topics and found no definite results but did find valuable info on rest of system: http://www.mywheelhorse.com/graphics/file/z_Other/ESM_810291R2.pdf. Also would a K-301 flywheel work appropriately on the K-241. or are they hp matched. Thanks for any help on this question! Share this post Link to post Share on other sites
Fordiesel69 271 #2 Posted October 29, 2013 A K241 and K301 flywheel will interchange. You will take the magneto out, mount a charging stator inside. You will need a 12v coil + ign lead, a condensor, and a bracket. I beleive the bearing plate behind the flywheel will accept a charging stator without swapping the plate itself. Source a cheap rectifier or build one. Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted October 29, 2013 I haven't done a big block Kohler, but I have swapped a K181. Ignition timing is the same between the mag and the coil ignition, the spark is timed by the points irrespective of whether they are triggering a magneto or an ignition coil. The condenser might be different between the two systems. I think you have all the parts listed. I had to swap the bearing plate on the motor I did as one had the mounts for the mag and the other had the mounting points for the stator. Share this post Link to post Share on other sites
groundhog47 445 #4 Posted October 29, 2013 Thanks both you guys, will be a fun project and allow me to convert to electric start and discard the rope. Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted October 29, 2013 (edited) Thanks both you guys, will be a fun project and allow me to convert to electric start and discard the rope. Actually I went the other way - converted to rope and ditched (yet another) battery I had to buy!! Actually a while back I was looking for a recoil/mag set up for a big Kohler, for the life of me I don't remember why. But once your project is up and running, if you want to sell the pieces you took off then let me know. Edited October 29, 2013 by sorekiwi Share this post Link to post Share on other sites
groundhog47 445 #6 Posted October 31, 2013 Thanks both you guys, will be a fun project and allow me to convert to electric start and discard the rope. Actually I went the other way - converted to rope and ditched (yet another) battery I had to buy!! Actually a while back I was looking for a recoil/mag set up for a big Kohler, for the life of me I don't remember why. But once your project is up and running, if you want to sell the pieces you took off then let me know. Will certainly do. The condenser I already figured interchanges, but may get the one closer to coil instead of by points. The mag stator at one time had a exciter coil having a lead routed to welder armature, it's gone. No telling how long may be have three other projects slowly evolving. Share this post Link to post Share on other sites
