VinsRJ 723 #1 Posted October 28, 2013 I have a Magnum 8 and was wondering if anybody has replaced the blower tins with K181 tins. I' m looking to make the Magnum 8 look more vintage for a project. Do they fit? Work with the Magnum flywheel? I'm asking prior to looking/purchasing the K181 tins. Thanks Share this post Link to post Share on other sites
Fordiesel69 270 #2 Posted October 28, 2013 Flywheel will be a problem, I dont believe a K tin will fit over it. Also can;t convert to points unless it is a **very** early one. Share this post Link to post Share on other sites
VinsRJ 723 #3 Posted October 28, 2013 (edited) Flywheel will be a problem, I dont believe a K tin will fit over it. Also can;t convert to points unless it is a **very** early one. Thank you... Wasn't looking to swap to points, just want the Magnum to look like a K-Series... Would anyone have the depth and width measurement for a K161/181 K-Series Blower tin on the flyewheel end? Those measurements alone may rule out the swap. Edited October 28, 2013 by VinsRJ Share this post Link to post Share on other sites
Fordiesel69 270 #4 Posted October 28, 2013 What I was trying to say is on some early magnums, there were point holes stamped but not drilled, and sometimes the cam with the lobe was still there. Only on some early ones.... Share this post Link to post Share on other sites
