dparke
Raider 10 ball joint fit B-80?
dparke
Does anyone happen to know if a left hand tie rod (or ball joint assembly, as the manuals call it) off of a 1969 Raider 10 will fit a 1975 B-80?  I'm almost finished with my B-80 rebuild, and just noticed that the ball stud on the inside of the left hand tie rod is snapped off.
The manuals list two different part numbers, but I thought maybe they were superseded at some point.
Thanks for any help!
-Dan
KC9KAS
My suggestion is to try it.
If they look the same, maybe they will swap.
McMaster-Carr has ball-joints/tie-rod ends....some are right hand thread and some are left hand threads....you can get what-ever you need/want.....They call them Heim Joints.
