privateer 1 #1 Posted October 21, 2013 Hi all, my tension pulley blew up and ruined my belt and in the process it took out one of the spindle pulleys. The deck is on a C-165 which puts the deck as a mid 80's. Question on replacement parts. I need two outside pulleys. The pulleys are 5" stamped not cast that are 3/4" keyed spindles. Can anyone tell me the part # for this pulley? Or a suitable replacement? I tried several schematics. They all show square or double D spindles. I also read somewhere that a wheel horse bulletin was posted years ago to eliminate the keyway and just use a lock washer and nut to tighten the pulley. Did this method work and Is this still the case? Thanks for all your help. Anyone have these spare parts for this deck? Share this post Link to post Share on other sites
Hodge71 665 #2 Posted October 21, 2013 I would suggest contacting Kelly. He is our spare parts guru on here and should be able to hook you up very reasonably. I have dealt with him numerous times and will treat you right!! Share this post Link to post Share on other sites
