Charlie Smith 142 #1 Posted October 20, 2013 Hello All Recently my poor little raider10 has been suffering abit, I've got a blown head gasket, it's been going strong but it's getting worse, with this colder weather coming I've brought a new head gasket for it, it's being shipped and is on it way, however this is the question where I need you guys, I have a Raider 10 with the Tecumseh HH100 10HP engine, once I replace the head gasket, is there a torque that the head bolts need tightening too? Or? Many thanks Share this post Link to post Share on other sites
WH nut 553 #2 Posted October 20, 2013 What size bolts, if they are 3/8s they are torqued o about 27 ft pound 5/16 about 18 Share this post Link to post Share on other sites
Martin 2,133 #3 Posted October 20, 2013 the manual says to torque them to 220-224 inch pounds. which should be around 18 ft lbs....... heres a manual link... Share this post Link to post Share on other sites
rick 258 #4 Posted October 21, 2013 In addition, you need to torque the bolts in the proper order, and in 50 inch pound steps. Share this post Link to post Share on other sites
Kelly 1,033 #5 Posted October 22, 2013 Also when you have the head off make sure it is flat, there are a few ways to do so, sand paper on a known flat surface and sand the head using a circular motion, till it looks flat, I have a 3" wide file I run over the heads in a cross pattern, or set it on a belt sander for a few passes, take it to a machine shop and have them true it up, how ever you do it, if it is flat it will seal better, and hold the gasket longer. 2 Share this post Link to post Share on other sites
Hodge71 690 #6 Posted October 22, 2013 Also when you have the head off make sure it is flat, there are a few ways to do so, sand paper on a known flat surface and sand the head using a circular motion, till it looks flat, I have a 3" wide file I run over the heads in a cross pattern, or set it on a belt sander for a few passes, take it to a machine shop and have them true it up, how ever you do it, if it is flat it will seal better, and hold the gasket longer. Good Info Kelly. I found that out on the one Suburban I bought. It had a bad gasket on the Kohler and when I checked, the head was way out. My Dad and I sanded for quite awhile til it was true. New gasket hasn't had an issue since then. Share this post Link to post Share on other sites
