dodgeit 0 #1 Posted October 14, 2013 P.O. put a Wisconsin Robin 12 hp on. The float in the carb is shot, and a Carb is stupid money on ebay. Looking for options. Somebody know of a different carb that will fit? Have the OEM carb. Another repower option. Thanks Share this post Link to post Share on other sites
jdog_kustoms 82 #2 Posted October 15, 2013 id put a kohler back on it Share this post Link to post Share on other sites
dodgeit 0 #3 Posted October 15, 2013 If I could find a reasonable replacement I would. Problem in this area is those are Gold and Platinum plated, if you can find one that is ready to roll. A rebuild able core is just Gold plated. Share this post Link to post Share on other sites
wallfish 18,221 #4 Posted October 15, 2013 Is it possible to fix the float? Solder the holes. Just out of curiosity, I looked on CL in SC and there's a running 12hp K301 Kohler in Greenville for $175. Not sure if that helps or not. Share this post Link to post Share on other sites
dodgeit 0 #5 Posted October 15, 2013 Thanks for the reply. Float is plastic so no go on soldering. Haven't thought to look on craigslist. Greenville is right up the road. Thanks again. Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #6 Posted October 15, 2013 Got a model number for the engine? I would think there's a replacement float that you could get reasonably. Share this post Link to post Share on other sites
dodgeit 0 #7 Posted October 15, 2013 Got a model number for the engine? I would think there's a replacement float that you could get reasonably. Its a W1-390 serial # 800302 Float # is 2246250508 for carb 2246230100 Share this post Link to post Share on other sites
Buckshot 1 15 #8 Posted October 17, 2013 Try this site: hmindustrial.com, 1-800-346-4331. Wisconsin engine parts. Share this post Link to post Share on other sites
dodgeit 0 #9 Posted October 18, 2013 Try this site: hmindustrial.com, 1-800-346-4331. Wisconsin engine parts. Apparently don't need money. Won't answer repeated phone calls or email. Looking for a carb with 1.800 or 46mm across the mounting flange bolt holes center to center with a 1.025 or 26mm throat Share this post Link to post Share on other sites
posifour11 723 #10 Posted October 21, 2013 If the float just has a hole in it, you may be able to seal it with a soldering iron. If you need some "fill", you can use a zip tie like a brazing or TIG rod. Share this post Link to post Share on other sites
dodgeit 0 #11 Posted October 27, 2013 Found a Kohler 301. So How do I determine I have the right Oil pan??? Share this post Link to post Share on other sites
