i967mustang
I never would have thought..........
i967mustang
I have a pair of Wheel Horse C160s, one is a 1976 8 speed and the second that I just picked up is a 1974 C160 auto with hydraulic lift. I decided since the 76 8 speed was completely redone and only has 5 hours on the engine I would convert it over to hydro with the hydraulic lift, how hard can that be right? What a surprise I got, I have been working on it for two days now and I think I finally have it done except for and idler pulley which was bad and a new drive belt. I would never have figured so many parts were different between the two tractors, when this is done I still have to put the 8 speed back in the second tractor because my brother wants that one.
daveoman1966
You are right....there are many diff's between the Auto and an 8-sp.  It'd be kinda like swapping out the manual trans for automatic on your old Ford 150...or vice versa.
Lemme know if you need parts as I have lots for the C-160 style Wheelhorse tractors.
My email is:
daveoman@windstream.net
Edited by daveoman1966
Kelly
Not only did you go from a stick to a hydro they made a body change in that time, they went from the flip up seat to the fixed seat, and that changed a bunch of stuff, at least it was all a bolt on, lots of them
546cowboy
One good thing about it is you'll really like that hydro and the lift, I probably wouldn't have done that myself unless the manual was junk. I would have most likely refurbished the C-160 Auto and swapped engines. Much easier to do. But whatever floats your boat as they say.
i967mustang
546cowboy, its not just the engine that stopped me from rebuilding the auto. When I redid the 160 8 speed I stripped it to a bare frame and started there, Stripped all the paint and primed and repainted like you would with a car. This tractor has base coat clear coat on it from bottom to top and I didn't want to lose a perfect tractor just to get the hydro and lift.
