waltsuz 12 #1 Posted October 11, 2013 (edited) Looking for 16x7.50-8 super lug type tires for a 520 front end with "0" luck, hopefully a 6 ply at that. Has anybody come up with an alternative to this. I know I have seen others running front wheel AG tires. I thought of trying a 6.50 but it seems best to see what others have done..Thanks everyone, Walt Here's my future backhoe: I have plans in the mail and I am ready to start cutting? Edited October 11, 2013 by waltsuz Share this post Link to post Share on other sites
kenw520hc 4 #2 Posted October 11, 2013 hi there, try www.greaterclevelandtire.com best price and selection i have found so far. good luck. i have used several 16x6.50-8 lug tires on 520 fronts. Share this post Link to post Share on other sites
Hodge71 691 #3 Posted October 11, 2013 Miller tire too. I have had great luck with them and Tucker Tire. Both have ebay stores and shipping is either free or very reasonable Share this post Link to post Share on other sites
JackC 617 #4 Posted October 11, 2013 Some recommend that when you switch from turf to bar tread tires you should go narrower. Narrower tires give better traction than wider ones due to more weight per square inch of contact. Share this post Link to post Share on other sites
IBleedRed 24 #5 Posted October 11, 2013 16x6.50-8 V61 HD 5-Rib 170/60-8 6 ply I got a pair of these from Millers and they are awesome for loader tractors Share this post Link to post Share on other sites
ol550 844 #6 Posted October 11, 2013 I would think the lug tire would be harder to turn than the rib tire as it would grip better. 1 Share this post Link to post Share on other sites
zieg72 209 #7 Posted October 12, 2013 For what it's worth, on the 520's with the gear reduction steering going from original 2 ply fronts to 4 ply the steering is noticeably easier. Stands to reason going to 6 ply and skinnier it should be easier yet...bar tires or not. Share this post Link to post Share on other sites
Jake Kuhn 1,591 #8 Posted October 12, 2013 http://www.millertire.com/products/lawn-garden-tires/16x6-50-8/16x6-50-8-firestone-3-rib-front-4-ply/ These are not lug tires...but I think a lot of people have put these on loader tractors and liked them. I think lug tires might make it hard to turn like ol550 said. Share this post Link to post Share on other sites
waltsuz 12 #9 Posted October 12, 2013 (edited) I honestly did not think about the ribb'ed type tire. Most I have been seeing on the net are the lug tires. The tires on my machine now gotta go, origional from 92" and dry rotted up bad. I know the loader build will pass the 300lb mark and something tuffer seems better. The link Jake just posted look like a good way to go. Another question: Does anyone feel the lift cylinder on this 520 will generate enough down pressure for a grader blade on the rear. I have a lot of wonderments in my head I may continue to ask about with this project. I am also considering a turning cylinder for the blade. I hope I don't clutter this site with what seems nonsence and everyone so far has been really good with the help. I love projects like this and this to me is going to be really cool. Thanks, Walt Edited October 12, 2013 by waltsuz Share this post Link to post Share on other sites
groundhog47 429 #10 Posted October 12, 2013 (edited) Thinking you are referring to the ag type tread someone on has some listed (8"), and as mentioned Millers. Edited October 12, 2013 by groundhog47 Share this post Link to post Share on other sites
dbartlett1958 99 #11 Posted October 16, 2013 I honestly did not think about the ribb'ed type tire. Most I have been seeing on the net are the lug tires. The tires on my machine now gotta go, origional from 92" and dry rotted up bad. I know the loader build will pass the 300lb mark and something tuffer seems better. The link Jake just posted look like a good way to go. Another question: Does anyone feel the lift cylinder on this 520 will generate enough down pressure for a grader blade on the rear. I have a lot of wonderments in my head I may continue to ask about with this project. I am also considering a turning cylinder for the blade. I hope I don't clutter this site with what seems nonsence and everyone so far has been really good with the help. I love projects like this and this to me is going to be really cool. Thanks, Walt Waltsuz, Regarding your lift cylinder question, I think it would do fine for a grader blade on the rear. The same cylinder will pick the front end of my 416 up with 200 pounds of me on top using my mid mount grader, so you should get some decent down pressure. Share this post Link to post Share on other sites
