pinecone 26 #1 Posted October 11, 2013 just got a new set of front 15-6-6 turf saver carlisle tires for a 312-8. originals worn thin. just wondering if there is a forward direction for the tire. i'm dumb as a mule with anything gas powered but i know there is no traction issue here. the pattern is -^^^- with the space bar being 1/2 inch on the side, then 4 inverted v's in the oppisite direction. i will go with the second, pointed forward unless told to do otherwise. valve inside, zerk outside. i'm learning. mowed till 7:30 (dark) here in ct. now till bud told me it would be wiser to go home. MANY buttressed roots covered with leaves, took the advise. Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted October 11, 2013 Somewhere on that tire should be a direction arrow if the manufacturer has a suggested one. Share this post Link to post Share on other sites
rmaynard 16,727 #3 Posted October 11, 2013 Carlisle Turf Savers are multi-directional, meaning they can go on either way. Share this post Link to post Share on other sites
953 nut 63,334 #5 Posted October 11, 2013 just got a new set of front 15-6-6 turf saver carlisle tires for a 312-8. originals worn thin. just wondering if there is a forward direction for the tire. i'm dumb as a mule with anything gas powered but i know there is no traction issue here. the pattern is -^^^- with the space bar being 1/2 inch on the side, then 4 inverted v's in the oppisite direction. i will go with the second, pointed forward unless told to do otherwise. valve inside, zerk outside. i'm learning. mowed till 7:30 (dark) here in ct. now till bud told me it would be wiser to go home. MANY buttressed roots covered with leaves, took the advise. What do you mean "Dumb as a mule"? They don't have to ask about rotation direction. Share this post Link to post Share on other sites
