Docwheelhorse 2,778 #1 Posted August 27, 2008 Does anybody have a GOOD voltage regulator for a Kohler 16 on a C165 Black Hood---I need the little 1 1/2" x 1 1/2" unit that was mounted next to the steering shaft up in the dash. The original cooked and then I put in a good used one (I thought) and it charged very nicely for a day... then the next time I started the tractor I got nothing. I did wire in one of the big clunky regulators from another Wheel Horse using alligator clip jumper wires and the charging system works fine. I just don't want to drill any holes or cut the wiring harness in order to retrofit another type regulator..... any help would be appreciated. My C165 and I thank you.... Tony Share this post Link to post Share on other sites
Sarge 3,470 #2 Posted August 28, 2008 If you have your original , post up a pic of it and whatever numbers are on the back . I have a local guy here that is a Kohler nut and works at an old shop that has a bunch of the original type regulators on the shelf . He had two for my 1277, original Delco units complete with an inch of dust for $35 each .... Sarge Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted August 28, 2008 Two different "animals" all together, Sarge. You're talking about a mechanical voltage regulator for a starter/generator system, and Tony needs a solid-state voltage regulator/rectifier for a 15 amp alternator. Those of us with the "silent-start" Kohlers will keep you in mind though. By the way..... :USA: Share this post Link to post Share on other sites
Docwheelhorse 2,778 #4 Posted August 28, 2008 Thanks Sarge, I will post a pic and see if he has a regulator on the shelf that resembles a dust bunny :banghead: Share this post Link to post Share on other sites
Sarge 3,470 #5 Posted August 28, 2008 Yes, I know his is solid state , they do have some of that type left in stock . This is one of those rare places that kept a good inventory and never sent it back . Funny part is it's primarily a steel supplier .... Thanks for the welcome too.... Sarge Share this post Link to post Share on other sites
