raider10-8 9 #1 Posted October 6, 2013 dose any one know if the raider series were supposed to be able to have plows? i have a 1971ish raider 10 and i got a plow for it and the handle the afjust the angle of the plow hits the right foot rest. maby i have the wrong plow? Share this post Link to post Share on other sites
Sparky-(Admin) 25,940 #2 Posted October 6, 2013 There are a few variations of the handle with different bends and even a straight one. I dont have a Raider but someone here will and should be able to tell you which handle will clear the footboards. Mike........... Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted October 6, 2013 Post a pic of the handle, some handles can be taken off turned around and have a notch to clear the foot rest, some you have to get a little mean with and put a bend in them, or you could have the wrong one all together, but that is just a handle swap not the whole blade. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,360 #4 Posted October 7, 2013 The 1971 dozer blade came in 2 packages. The blade ?do=embed' frameborder='0' data-embedContent> Newer version http://www.wheelhorseforum.com/files/file/85-blade-dozer-42in-1970-1973-blade-6-9622-om-ipl-newer-a-5192pdf/ Newest version ?do=embed' frameborder='0' data-embedContent> The completeing kit Garry Share this post Link to post Share on other sites
raider10-8 9 #5 Posted October 7, 2013 ok thanks guys Share this post Link to post Share on other sites
Humm 2 #6 Posted October 7, 2013 I got a Raider 12 last spring and had the same problem, I couldn't lock the plow to stay up. I found a longer linkage for lifting it in the bucket of parts I got with it ,and that did the trick. Share this post Link to post Share on other sites
raider10-8 9 #7 Posted October 7, 2013 yaaa that^ happened to me to but my problem is not the lifter its the angler handle. but i think if i take it off and reverse it like they said^^^^ i think that might work. 1 Share this post Link to post Share on other sites
Humm 2 #8 Posted October 7, 2013 I just checked, it looks like a home made extension, about 3 inches. Share this post Link to post Share on other sites
