Sarge 3,465 #1 Posted August 26, 2008 Got an original 1277 that finally barfed it's pump last year and swapped in the complete hydro from my 876 . Question is , I have a C-series hydro pump gear and wonder if it can be swapped over to fit the 1277's original axle ?? Also, where can I find the correct pump gear's plungers/springs to make the hydro lift valves work correctly ? Currently using the 876's hydro lift cylinder/valve/lines and did find almost all replacement valve parts from Toro but it's on the weak side, probably from the old vane pump getting tired . BTW, awesome site and thanks to an Ebay member for pointing me this direction ! I'll try to post up some pics of the ol' 1277 and 876 soon . Sarge Share this post Link to post Share on other sites
pond195520032003 27 #2 Posted August 26, 2008 :lol: Sarge, i believe the pump will interchange as for the parts TT will be better able to point you in the right direction glad you found us and to the ebay seller for pointing the way :thumbs: Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,606 #3 Posted August 26, 2008 Sarge, Are you the Sarge from MTF? Just curious, anyways, welcome to the site. Share this post Link to post Share on other sites
Sarge 3,465 #4 Posted August 28, 2008 Well, thanks a bunch for the nice welcomes .... But, what is MTF?? I'm the Weber Sarge , just Google any info for Weber carbs , been there , done doing that for now ....lol . Just a note, anyone that needs help with their Weber let me know or shoot an email , I can usually help . I'm nearly sure the pump gears will interchange , just got to get a set of gaskets for the swap . The C series axle section was damaged, looks like someone engaged the parking brake while it was moving at a fair clip and broke the parking brake teeth off . Gears are fine and it also has an 8 pinion diff , so if the one out of the 1277 is a 4 pin I'll swap it out . Now, the drawings I've found show a different style of diff so gotta get that one apart next week and see what's up there . Otherwise, hope to have a much stronger hydro in it soon as the 876's is a bit on the weak side although she'll still back up a very steep hill . I can't begin to tell you guys how much I love this old tractor . 41 years old , never fails to start , mows quite well despite it's age, will pull a house if asked to and generally just makes me happy to own it . Spent most of today welding a bad rip in the left side of her 48" deck , caught it on a 3" high tree stump and bent the side it where it was worn down from age allowing the blade to rip it's side wide open . Thank God I bought that Tig last year ....can't even see the repair now !!! Sarge Share this post Link to post Share on other sites
bell 11 #5 Posted August 28, 2008 Well, thanks a bunch for the nice welcomes .... But, what is MTF?? I'm the Weber Sarge , just Google any info for Weber carbs , been there , done doing that for now ....lol . Just a note, anyone that needs help with their Weber let me know or shoot an email , I can usually help . I'm nearly sure the pump gears will interchange , just got to get a set of gaskets for the swap . The C series axle section was damaged, looks like someone engaged the parking brake while it was moving at a fair clip and broke the parking brake teeth off . Gears are fine and it also has an 8 pinion diff , so if the one out of the 1277 is a 4 pin I'll swap it out . Now, the drawings I've found show a different style of diff so gotta get that one apart next week and see what's up there . Otherwise, hope to have a much stronger hydro in it soon as the 876's is a bit on the weak side although she'll still back up a very steep hill . I can't begin to tell you guys how much I love this old tractor . 41 years old , never fails to start , mows quite well despite it's age, will pull a house if asked to and generally just makes me happy to own it . Spent most of today welding a bad rip in the left side of her 48" deck , caught it on a 3" high tree stump and bent the side it where it was worn down from age allowing the blade to rip it's side wide open . Thank God I bought that Tig last year ....can't even see the repair now !!! Sarge Sarge! What a small world! I wondered if you were the same Sarge from zuwharrie... You're gonna LOVE this place! Share this post Link to post Share on other sites
perry 82 #6 Posted August 28, 2008 to the ebay seller for pointing the way ...... glad to see you made it here. ... ..... . Share this post Link to post Share on other sites
Sarge 3,465 #7 Posted August 28, 2008 Okay, so anyone know where to find the correct valves, plungers and springs for hydro lifts and such for the C series hydro gear unit ?? Sarge Share this post Link to post Share on other sites
perry 82 #8 Posted August 29, 2008 Okay, so anyone know where to find the correct valves, plungers and springs for hydro lifts and such for the C series hydro gear unit ?? Sarge sorry cant help ya on your parts . may be easier to find a whole parts tractor and use the whole rearend. roll it up , 4 bolts and your done. Share this post Link to post Share on other sites
Sarge 3,465 #9 Posted August 31, 2008 If nothing else, I do have the dimensions off the valves I bought from a local Toro dealer , looks like they sourced the last one in stock for me as they no longer show up as good numbers . Might have to coax a friend to bang some out on his lathe this winter . Just the spring is touchy, it's weight pull determines valve load/hydro pressure to the implements . Man, I need a shop and a paint booth badly... Sarge Share this post Link to post Share on other sites
big mike 13 #10 Posted September 1, 2008 What hydro is it? If it is a 15U Sunstrand I have many used ones and can help you with parts. Share this post Link to post Share on other sites
pond195520032003 27 #11 Posted September 1, 2008 Mike, iy is the SunStrand :banghead: Share this post Link to post Share on other sites
Sarge 3,465 #12 Posted September 3, 2008 The C-series pump/trans is a model #90-1140 / ser#03 PB 34460 piston type . The gear case has a broken park brake gear, couple of blown bearings but otherwise all gears are fine and axles are ok - although some idiot welded the flange on one side . Not sure if I should set the 876 up with a hydro lift or just use the manual setup (have all the correct parts) since it's only getting a 42" deck and plow . If I'm correct on drawings, the pump has the lift valves already installed .... Sarge Share this post Link to post Share on other sites
