IronDuke 4 #1 Posted September 29, 2013 Hey, i have been trying to restore my 66' lawn ranger but i have not been able to get any spark. Any ideas on what it could be? Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted September 29, 2013 If it's the original Tecumseh the points, condenser and magneto are all behind the flywheel. I don't remember how you shut the thing off, there is probably a kill wire coming out from the same place to ground the mag and kill the spark. Check that first, if that wire is shorted to ground you will have no spark. If that doesn't fix it, pull the flywheel and have a look at the points etc. 1 Share this post Link to post Share on other sites
squonk 43,465 #3 Posted September 29, 2013 If it's the original Tecumseh the points, condenser and magneto are all behind the flywheel. I don't remember how you shut the thing off, there is probably a kill wire coming out from the same place to ground the mag and kill the spark. Check that first, if that wire is shorted to ground you will have no spark. If that doesn't fix it, pull the flywheel and have a look at the points etc. Good tip! My 704 was running erratic like the carb mixture was off. Turned out to be the kill wire was rubbed thru and it was vibrating and just touching the steering shaft. Share this post Link to post Share on other sites
AMC RULES 37,191 #4 Posted September 29, 2013 First...try a different(known good)spark plug. 1 Share this post Link to post Share on other sites
squonk 43,465 #5 Posted September 29, 2013 First...try a different(known good)spark plug. Share this post Link to post Share on other sites
IronDuke 4 #6 Posted September 29, 2013 thanks for the help 1 Share this post Link to post Share on other sites
AMC RULES 37,191 #7 Posted September 29, 2013 Keep us updated here, let us know how it goes. Share this post Link to post Share on other sites
IronDuke 4 #8 Posted September 29, 2013 i just pulled off the case covering the flywheel now what should i be looking for? Share this post Link to post Share on other sites
IronDuke 4 #9 Posted September 29, 2013 i am trying to get the fly wheel itself off but its not wanting to come off, any ideas on how to take it off? Share this post Link to post Share on other sites
sorekiwi 761 #10 Posted September 30, 2013 Here is a link to the manual: http://www.wheelhorseforum.com/files/file/665-engine-tecumseh-l-head-3-11hp-service-manualpdf/ The flywheel is on a taper. Share this post Link to post Share on other sites
