Mr. 856 170 #1 Posted September 25, 2013 Putting the 856 back together and seem to be missing two little pieces that im certain have a big purpose. The bigger problem seems to be the parts are obsolete. The part #'s in question are #6638 Spacer and #1536 bearing. these parts are shown in the owners manual I have for the rotary mower RM-327 & RM-367. the spacer and bushing are needed for the pulley on the right hand bracket. I cant find them anywhere and I thought I was pretty good about putting everything together. now mind you I didn't look the manual over as I was taking apart and didn't label every part per the manual as they came off. Is it possible the spacer and bushing weren't there to begin with? would it even work right without them? These are the situations that make a "restore" all the more fun. any one know another source? part # cross reference or anything to get me through this? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,592 #2 Posted September 25, 2013 1623 idler pulley replaced by Toro 92-7102 From my notes the 1536 bushing is 3/8" x 11/16" x 3/16". Have seen the 1623 pulley with a 1614ZZ bearing in it. #1623 OEM 1961 1962 1963 1964 1965 1966 1967 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1991 1992 1993 #92-7102 OEM 1994 1995 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 1623 is also the clutch idler pulley for the transmission on the 856. Garry 1 Share this post Link to post Share on other sites
groundhog47 347 #3 Posted September 25, 2013 from Garry, "From my notes the 1536 bushing is 3//8" x 11/16" x 3/16"." I hunted for hours for my bushing. The pic makes it look BIG but it is very small. I had slid it back on bolt and with that size, if mine is orig, was just small enough to over look. Share this post Link to post Share on other sites
Mr. 856 170 #4 Posted September 26, 2013 Gary thank you for that info.looks like I do have the same bushing on the on the rear idler of the tractor. probably going to try and take that some where and match it up. what about the "spacer"? whats that all about? my idler wheel/bearing is fine......the spacer is M.I.A. Share this post Link to post Share on other sites
