Arild 0 #1 Posted September 21, 2013 Hello:-) Anyone know the dimensions of the wheels to my GT 14 1971 model? The rims 15 x 7 JA and have this number inscribed: 0417239 I would like to know the correct dimensions of the offset, bolt circle / bolt pattern, and Hub hole. So that I can find new wheels, also in another dimension if possible. Ther is a lot of spase if I changed the offset by mowing the wheel out a few cm. But I do not think the hub would like that. Arild Share this post Link to post Share on other sites
groundhog47 447 #2 Posted September 21, 2013 (edited) Hei Arild, this manual: Garry gwest_ca lists item number: 280, pn: 8285 as tire 27" x 9.50"-15. It's for a 1972 GT14 1-0502, Should be same or near, doesn't list hub or wheel hub hole size but should be very sug or tight fit. Hope that helps. Tak Use this one from Garry gwest_ca, has picture of parts and si 1971 GT14 1-0500: http://www.wheelhorseforum.com/files/file/2217-tractor-1971-gt-14-1-0500-tiplpdf/ Same line item number =280, pn: 8285 Edited September 21, 2013 by groundhog47 1 Share this post Link to post Share on other sites
Arild 0 #3 Posted September 24, 2013 Thanks:-) This is a start, I need any paper I am able to get my hands on to get this Wheel Horse up and go. I also need papers an measures on the frame and the snow blade attached. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,011 #4 Posted September 24, 2013 Dozer blade manual and Came in 2 packages at the time. Garry Share this post Link to post Share on other sites
