WHwest8597 85 #1 Posted September 19, 2013 Anyone know where to get a brake pad for a 314-8 that cost less then the $70 that Toro charges. Share this post Link to post Share on other sites
Hodge71 691 #2 Posted September 19, 2013 You can buy friction material from McMaster-Carr for pretty cheap and glue it on yourself. I did it with my 18 auto turning brakes. Your going to have to find something of the same radius to clamp against to make it work though Share this post Link to post Share on other sites
daveoman1966 3,881 #3 Posted September 19, 2013 (edited) If you refer to lining of item 10 in this schematic (part # 9593), I have successfully used a cut-to-length chunk of an old leather belt. If you think it is too thin, glue two pieces together, then to the metal band with an expoy of some sort...I used POR15 for this. Of course, Ebay. . Edited September 19, 2013 by daveoman1966 Share this post Link to post Share on other sites
swarfeater 49 #4 Posted September 19, 2013 i got some brake band and clutch banding from ebay, 2' for $12. a little work and presto. there is a sellor that carries all sizes of the stuff, rivet or ht epoxy it on. Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #5 Posted September 19, 2013 (edited) 6175K813 mcmaster carr Thick. Wd. Per Ft. Per Ft. 3/16" 1 1/2" 6175K813 $4.70 Edited September 19, 2013 by DoctorHfuhruhurr Share this post Link to post Share on other sites
Marv 994 #6 Posted September 20, 2013 I used the McMaster Carr material on my D200 brake band. Fits and works good. Marvin Share this post Link to post Share on other sites
