WHwest8597
Brake Pad for 314-8
WHwest8597
Anyone know where to get a brake pad for a 314-8 that cost less then the $70 that Toro charges.
Hodge71
You can buy friction material from McMaster-Carr for pretty cheap and glue it on yourself. I did it with my 18 auto turning brakes. Your going to have to find something of the same radius to clamp against to make it work though
daveoman1966
If you refer to lining of item 10 in this schematic (part # 9593), I have successfully used a cut-to-length chunk of an old leather belt.  If you think it is too thin, glue two pieces together, then to the metal band with an expoy of some sort...I used POR15 for this.
Of course, Ebay.
Edited by daveoman1966
swarfeater
i got some brake band and clutch banding from ebay, 2' for $12. a little work and presto. there is a sellor that carries all sizes of the stuff, rivet or ht epoxy it on.
DoctorHfuhruhurr
 6175K813 mcmaster carr
Thick. Wd.   Per Ft.   Per Ft.
3/16" 1 1/2" 6175K813 $4.70
Edited by DoctorHfuhruhurr
Marv
I used the McMaster Carr material on my D200 brake band. Fits and works good.
Marvin
