nsmith 2 #1 Posted August 25, 2008 Hello all, I am restoring a 310-8 and in the process I found it is leaking gear oil out the side transmission were the break shaft is. My question is can I replace this seal without taking apart the transmission? Any other advice regarding this is great Thanks nsmith Share this post Link to post Share on other sites
Stigian 1,234 #2 Posted August 25, 2008 Hiya nsmith Im not 100% sure on this, but im sure some of guys will correct me if im wrong Im sure i have been told the leaking axle seals can be replaced with taking the trans apart :USA: Share this post Link to post Share on other sites
kpinnc 15,671 #3 Posted August 25, 2008 Ian is right. You can replace the seal without opening the tranny, as long as there isn't any play in the bearing/ shaft. Kevin Share this post Link to post Share on other sites
