cheesegrader 433 #1 Posted September 16, 2013 Now that I have two 520H tractors, what do I need? A third one! I thought I would trade implements as I use them, but... The loader never comes off the new one, and the old one has a 60" deck all summer, and a 2-stage blower/cab all winter. Neither of these are fun to remove, and I have a fair amount of plowing and grading to do each year. So I am thinking I need another tractor. Snowblade in the winter, rear box blade/plow/gravel blade/grader and tiller in the summer. I think an 8-speed would be better for these tasks, and a 520-8 would be easiest as far as swapping parts, but they are sooo rare. I've seen a few 416-8's for sale locally, and one 518-8, but they were all really rough, and overpriced. What would you look for as the best option for a dedicated ground-engaging implement tractor? Share this post Link to post Share on other sites
Dieselcowboy 210 #2 Posted September 16, 2013 I have a C160auto that does a very good job with all the tasks you listed. I have not been able to run it out of power yet. It is just a good heavy weight all around. Plus mine has hyd lift. That is almost a must as s.blowers and tillers are so heavy on the handle. Share this post Link to post Share on other sites
Tankman 3,523 #3 Posted September 16, 2013 Cheese Head you are showing early symptoms of classic WHA (Wheel Horse Addiction). Why of course you do need a third Stallion. Who doesn't? 1 Share this post Link to post Share on other sites
AMC RULES 37,196 #4 Posted September 16, 2013 I read, you could swap an 8 speed rear into one of your 520's. 1 Share this post Link to post Share on other sites
cheesegrader 433 #5 Posted September 16, 2013 I don't want to swap out my hydro's. I need them just the way they are! I like the idea of hydraulic lift, but I think the plowing and grading is awfully hard on the rear end. Seems that an 8 speed would take the abuse better. A bigger C series might do, I just don't have any experience with them. I like the bulk of the D's, but worry about getting parts. Oh, the addiction is getting BAD! Share this post Link to post Share on other sites
JackC 617 #6 Posted September 17, 2013 [What would you look for as the best option for a dedicated ground-engaging implement tractor?] For plowing and other ground engagement tasks and for the money you can't beat a D Series. Share this post Link to post Share on other sites
leeave96 490 #7 Posted September 17, 2013 I don't want to swap out my hydro's. I need them just the way they are! I like the idea of hydraulic lift, but I think the plowing and grading is awfully hard on the rear end. Seems that an 8 speed would take the abuse better. A bigger C series might do, I just don't have any experience with them. I like the bulk of the D's, but worry about getting parts. Oh, the addiction is getting BAD! I wouldn't be to feared of damaging a hydro rear end vs a gear drive. If you get one of the higher end tractors like another 520H, you will have an 8 pinion tranny and I'm pretty sure a 1-1/8 inch axle, coupled to the Eaton 1100. That's a mighty combo. The hydro lift will be much appreciated with those heavy implements. I would put the tranny/axle set-up in my 520H tractors against my fine 314-8 gear drive tranny any day - I consider both designs equal in terms of strength. That's my story and I'm stickin' to it. Good luck, Bill 1 Share this post Link to post Share on other sites
bigfkd22 11 #8 Posted September 18, 2013 My c160 got away from me (don't ask dang near killed me ) hit my house (brick)and with wheel weights and chains and spun the tires until I got it shut down. I thought it was going to knock the house off the foundation! I plow and till the whole neighborhoods gardens with my c161-h and c160-h. They might not be as tough as 8 speed but there pretty tough. I have a 520xi as well so I think I have something pretty strong to compare too. Also who wants to keep lifting the tiller or plow without hydraulics? I don't mind tilling with the hydro at all. Just my 2 cents. 1 Share this post Link to post Share on other sites
