bean 85 #1 Posted September 12, 2013 how do you install the plug wire into this style of magneto? it looks like it has a 1/16" diameter rod that inserts into the core of the wire, as you push it in. do you need to add any sort of adhesive? Share this post Link to post Share on other sites
rmaynard 16,404 #2 Posted September 12, 2013 (edited) On old lawn mower engines that had the plug wire pull out, I would clean the hole as best as I could, then coat the part of the wire that goes into the hole with clear silicone caulk/glue, reinsert it, and let it cure over night. Edited September 12, 2013 by rmaynard Share this post Link to post Share on other sites
bean 85 #3 Posted September 12, 2013 thank you sir, that was a quick response Share this post Link to post Share on other sites
groundhog47 347 #4 Posted September 12, 2013 thank you sir, that was a quick response Just tagged this for future ref, an issue I have also, Thanks Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted September 13, 2013 I've used hot-glue in the past and it has seemed to hold up ok. Share this post Link to post Share on other sites
Save Old Iron 1,571 #6 Posted September 14, 2013 This may be of some help, I would use epoxy to seal the wire. Most silicone products are permeable to oxygen. Share this post Link to post Share on other sites
