qd-16 14 #1 Posted September 9, 2013 I'm working on an rj35 that I picked up a couple yrs. ago and I had a few questions: I am missing the tension spring that goes here p/n 1129. I'm going to try to match one up and need to know approx. how long this spring should be?? http://i437.photobucket.com/albums/qq100/qd-16/037_zps22c45795.jpg I was also wondering what this bracket with the hole is?? http://i437.photobucket.com/albums/qq100/qd-16/039_zps363370d7.jpg The last thing I need to know is about the belt that goes from the vari pulley to the jack-shaft pulley under the seat....My rj35 has the 6" pulley so what belt length do I need? Thanks for any info! Al. 1 Share this post Link to post Share on other sites
buckrancher 2,694 #2 Posted September 9, 2013 bracket does not belong on tractor was added by someone. the spring you can use the standard clutch /brake spring from early sixies tractors(702,753 etc.) Brian Share this post Link to post Share on other sites
SousaKerry 503 #3 Posted September 9, 2013 You may find this video series helpful the guy who does them probobly knows as much or more then anyone else on here does about the early tractors https://www.youtube.com/user/VinsGN Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,495 #4 Posted September 9, 2013 I believe I got this from the tractor drive belt charts. Wheel Horse 1556 nla {4Lx20"} Tractor drive belt (RJ-35 with 6", 6-1/2", 7" jackshaft pulley) Wheel Horse 1564 nla {4Lx18.9"} Used with 1556 belt tractor drive belt (RJ-35 with 6" jackshaft pulley) This length looks wrong and should be approximately 35"? Wheel Horse 1553 nla {4L/Ax36"} Used with 1556 belt tractor drive belt (RJ-35 with 6-1/2" jackshaft pulley) Wheel Horse 1552 nla {4Lx37"} Used with 1556 belt tractor drive belt (RJ-35 with 7" jackshaft pulley) Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,495 #5 Posted September 9, 2013 1129 spring shows up in these parts lists 02-08BP01, B-82 3-Speed Tractor, 1980 02-11BP02, B-115 5-Speed Tractor, 1980 02-11BX01, B-112 3-Speed Tractor, 1980 02-16BP01, B-165 Twin 5-Speed Tractor, 1980 1-8751, Lawn Ranger Tractor, 1970 2-0200, Lawn Ranger Tractor, 1971 2-0210, Lawn Ranger Tractor, 1971 2-0211, Ranger 800 Tractor, 1972 2-0220, Ranger 700 Tractor, 1973 2-0230, Ranger 800 Tractor, 1973 5-0200, 32" Side Discharge Mower, 1970 5-0201, 32" Side Discharge Mower, 1970 6-1111, 42" Dozer Blade, 1968 6-1121, 54" Snow/Dozer Blade, 1968 6-2111, 42" Dozer Blade, 1968 82-08BP01, B-81 4-Speed Tractor, 1978 82-11BP01, B-111 4-Speed Tractor, 1978 92-08BF01, B-81 6-Speed Tractor, 1979 92-11BF01, B-111 6-Speed Tractor, 1979 92-11BP01, B-111 4-Speed Tractor, 1979 BD-426, 42" Snow/Dozer Blade, 1966 BD-4261, 42" Snow/Dozer Blade, 1961 BD-4262, 42" Snow/Dozer Blade, 1962 BD-4263, 42" Snow/Dozer Blade, 1963 BD-4264, 42" Snow/Dozer Blade, 1964 BD-4264A, 42" Snow/Dozer Blade, 1965 BD-4267, 42" Snow/Dozer Blade, 1961 BD-4267, 42" Snow/Dozer Blade, 1962 BD-4267, 42" Snow/Dozer Blade, 1963 BD-4267, 42" Snow/Dozer Blade, 1964 BD-4267, 42" Snow/Dozer Blade, 1965 BD-4267, 42" Snow/Dozer Blade, 1966 BD-4267, 42" Snow/Dozer Blade, 1967 BD-4271, 42" Snow/Dozer Blade, 1961 BD-543, 54" Snow/Dozer Blade, 1963 BD-543, 54" Snow/Dozer Blade, 1964 BD-543, 54" Snow/Dozer Blade, 1965 BD-546, 54" Snow/Dozer Blade, 1967 SPR-42, 42" Snow Blade, 1959 ST-302, 30" Snowthrower, 1962 ST-3072, 30" Snowthrower, 1962 ST-323, 32" Snowthrower, 1963 ST-324, 32" Snowthrower, 1964 ST-325, 32" Snowthrower, 1965 ST-374, 37" Snowthrower, 1964 ST-375, 37" Snowthrower, 1965 Garry Share this post Link to post Share on other sites
VinsRJ 723 #7 Posted September 10, 2013 You may find this video series helpful the guy who does them probobly knows as much or more then anyone else on here does about the early tractors https://www.youtube.com/user/VinsGN That's my YouTube Channel, I truely appreciate your comment! As of the spring I just go down to my local hardware store and match it up as close as I can find. So long as the tension seems to be close the very drive system will work as it should. Fine tuning the drive is all through the belt/veri drive pully adjuster. I personally like to remove the reveres disc and adjust the belt system so when you pull the speed selector all the way back the drive goes into full nutral instead of engaging the reverse. It just feels safer to me. The braket on your hood stand is an add on as stated above. Share this post Link to post Share on other sites
