stevasaurus 23,659 #1 Posted September 7, 2013 Is there a way to make an "anti-clockwise" starter/generator turn clockwise for an 8 hsp Kohler engine??? Please help. The horse is a Commando 8. I was helping Jan van der Zwaan in the Netherlands with shipping for his starter generator (the parts house does not ship over seas). Share this post Link to post Share on other sites
WH nut 553 #2 Posted September 7, 2013 Im not sure, but being a DC motor, cant you just change polarity? Share this post Link to post Share on other sites
dclarke 4,117 #3 Posted September 7, 2013 Steve, you have to put different field coils in it to make it turn the other direction. Any starter repair shop could do that for you. 2 Share this post Link to post Share on other sites
953 nut 64,872 #4 Posted September 7, 2013 Im not sure, but being a DC motor, cant you just change polarity? No, wish it was that easy. When I first got my '48 Ford it was 6 volt positive ground. I changed it over to 12 volt negative ground and the old 6 volt starter turned the old flat head over real fast but in the proper rotation. Share this post Link to post Share on other sites
stevasaurus 23,659 #5 Posted September 10, 2013 Thanks guys..I needed a direction to head in. Share this post Link to post Share on other sites
WheelHorse79 271 #6 Posted September 10, 2013 Sounds like I may have a problem too with my 854. I bought a new replacement S/G off a web site that had a specific listing for my series 301XXX 8 HP Kohler. When I got the new S/G, it has label that says "anit-clockwise". So, it sounds like this S/G won't work even though the cross reference shows it as being correct for my engine. I haven't been able to get the S/G to work yet. Any way to tell if it will work before hand? Thanks! Share this post Link to post Share on other sites
stevasaurus 23,659 #7 Posted September 11, 2013 That is what happened to us. The paper work is correct, but the starter has the CCW tag. Cub Cadet's Kohlers turn in the opposite direction from the Wheel Horse Kohlers...hence the CCW starter / generators. WE ordered ours from Pat's Small Engine Plus in Minnesota. Is that where you got yours from?? I suggest you call them and tell them what happened...they should be able to get you the right one. Our problem is that they do not ship over seas. They shipped it to me here in the states, and I shipped it to Jan in the Netherlands. The cost of returning it is cost prohibitive...shipping was like $98.00. We are looking at other options. Let us know what happens WheelHorse79. Thanks Share this post Link to post Share on other sites
C-101plowerpower 1,606 #8 Posted September 11, 2013 That is what happened to us. The paper work is correct, but the starter has the CCW tag. Cub Cadet's Kohlers turn in the opposite direction from the Wheel Horse Kohlers...hence the CCW starter / generators. WE ordered ours from Pat's Small Engine Plus in Minnesota. Is that where you got yours from?? I suggest you call them and tell them what happened...they should be able to get you the right one. Our problem is that they do not ship over seas. They shipped it to me here in the states, and I shipped it to Jan in the Netherlands. The cost of returning it is cost prohibitive...shipping was like $98.00. We are looking at other options. Let us know what happens WheelHorse79. Thanks other options would be like i do, a family friend of ours regularly ships seacontainers full with tractors and stuff from the states to here(netherlands), almost all the small parts we order in the states get send to the guy that loads the container and all the small parts are just "thrown" in there. koen 2 Share this post Link to post Share on other sites
WheelHorse79 271 #9 Posted September 11, 2013 Well, to add to my confusion, it all depends on what side of the "clock" you're looking at to determine clockwise and counter-clock wise. I was looking at my 854 and figured that if the S/G rotated CCW, the starter pulley on the crank would rotate CCW as well. However, if you go to the other side of the tractor where the output PTO shaft is, it will rotate clock wise. I believe the drive belt running from the PTO shaft to the transmission input pulley needs to turn clockwise, to turn the rear wheels clockwise, so that the tractor moves forward. Isn't my thinking correct? If so, the the CCW rotation of the S/G would be correct. Please let me know what you all think. Thanks, Michael Share this post Link to post Share on other sites
stevasaurus 23,659 #10 Posted September 11, 2013 The direction of the starter / generator is determined by when you look at the pulley end of the starter. The transmission pulley on your transmission is supposed to rotate counter clockwise as is the engine pulley when you look at them straight on. Therefore, a CCW starter turns the engine the wrong way for a Wheel Horse Kohler. It will not start and it will throw gas out the carb. You need to have a clockwise starter. Now if you could figure eight the fan belt... Share this post Link to post Share on other sites
Anglo Traction 761 #11 Posted September 11, 2013 It's a shame the CCW S/Gen can't be mounted pulley end to PTO side and a Pulley on that side of the Crank, as it would turn the Engine the right way 1 Share this post Link to post Share on other sites
buckrancher 2,696 #12 Posted September 12, 2013 The direction of the starter / generator is determined by when you look at the pulley end of the starter. The transmission pulley on your transmission is supposed to rotate counter clockwise as is the engine pulley when you look at them straight on. Therefore, a CCW starter turns the engine the wrong way for a Wheel Horse Kohler. It will not start and it will throw gas out the carb. You need to have a clockwise starter. Now if you could figure eight the fan belt... both kohler motors turn the same way Steve (cub/wheelhorse) one uses the pto side for starting and the other uses the flywheel side that why there's cw/ccw and the need for different SG's for both brands Brian 1 Share this post Link to post Share on other sites
CasualObserver 3,415 #13 Posted September 12, 2013 There are plenty of people who have done this out in the world wide web. This link will help you find some.-----> http://bit.ly/1d8OM1K Steve... I'll be waiting for a middle finger and look of disgust in Jacksonville! 4 Share this post Link to post Share on other sites
Jeff-C175 7,207 #14 Posted September 12, 2013 Excellent link Jason! I have plenty of uses for that one! thanks! 1 Share this post Link to post Share on other sites
WheelHorse79 271 #15 Posted September 13, 2013 Thanks for the replies everyone. I ordered another S/G that turns CW. Now, I have to return the wrong one I got from Pete's Small Engine. It's a shame that their product cross reference is wrong. Caveat Emptor. 1 Share this post Link to post Share on other sites
jrc0528 20 #16 Posted September 13, 2013 (edited) Hmm... I've yet to pull a S/G apart, but switching directions should just be a matter of reversing the wires feeding either the brushes or the field coil(s). This must be dont inside the casing, as switching the polarity of the wires outside the unit will have no effect. Edited September 13, 2013 by jrc0528 Share this post Link to post Share on other sites
stevasaurus 23,659 #17 Posted September 13, 2013 Thanks for all the information on this issue guys. Koen, Jan may try to get in touch with you...thanks. I think he lives in Leermans...do not know if that is close to you or not. 1 Share this post Link to post Share on other sites
Dutch Commando8 5 #18 Posted September 13, 2013 Hey there Steve and other supporters I had contact with Koen en will see if ordering a new s/g is an option. At first I will try to reverse the S/G myself by reversing the wires, however.... the insides if both cw and ccw look exactly the same so I,m afraid It,s the inner piece that needs to be reversed or re winded. If that,s so, I,m gonna take it to a s/g specialist here in Holland. Steve, skype tomorrow at 15.00 your time? 1 Share this post Link to post Share on other sites
Dutch Commando8 5 #19 Posted September 14, 2013 Got it!! I changed polarity by using the new inside of the S/G in the old outside, It,s turning the right way now, and running again! 2 Share this post Link to post Share on other sites
stevasaurus 23,659 #20 Posted September 14, 2013 :happy-jumpeveryone: EXCELLENT JAN. 1 Share this post Link to post Share on other sites
Anglo Traction 761 #21 Posted September 14, 2013 Got it!! I changed polarity by using the new inside of the S/G in the old outside, It,s turning the right way now, and running again! Well Done that man right there! . Real glad you've managed to sort it. Share this post Link to post Share on other sites
