Marshall 0 #1 Posted September 6, 2013 Good morning! First time post...........but not the last. I have a 1988 model 414-8 that I bought new. It has been a great tractor! Over the past several years I have been looking for attachments that will fit this model. My problem is that I am confused as to which ones will fit. Downloaded the guide book for attachments up thru 2000 year and that has helped as to what Wheel Horse offered. WIth that info I was able to get a snow blower that I know will work and it will get a work out this winter. The one attachment that I could use right away is the mid mounted scikle mower, not sure who made them, what model numbers would work, etc, etc. Another attachment that would be handy is a front mounted 540 RPM PTO. I have seen these for JD, did anyone make one for WH? I can fab one of these myself, if I could just get some free time. At this point I would like to start a wish list of any and all attachments that would fit on the 414-8. Yes I know this likely to become an obession, but hey, whats one more. Thanks At some point I hope to give back to this forum, right now I am newbie that needs some help. Marshall Share this post Link to post Share on other sites
953 nut 60,137 #2 Posted September 6, 2013 The Haban sickle bar mower for the will come up from time to time on ebay, but any Haban mower can be adapted to work with your 414-8. It would take a good mechanic to do it, but if you plan to fabricate a 540 RPM PTO yourself then you probably could do it. Most of the attachments for 1965 and later that use the mid mount tach-a-matic will fit yours. I guess you have found the "Implements" tab on this site and seen how many you have to select from. Good luck and keep us posted. Share this post Link to post Share on other sites
KC9KAS 4,744 #3 Posted September 7, 2013 Marshall... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,499 #4 Posted September 7, 2013 540 rpm farm pto PTO-66 8-3211 and sometimes written as 83211 - try it both ways http://www.wheelhorseforum.com/files/file/1073-pto-farm-implement-1968-1969-8-3211-om-ipl-386-1pdf/ Garry Share this post Link to post Share on other sites
