Butch 194 #1 Posted September 5, 2013 Pulled my 36" deck off my C-85 to instal the mower blade that came off...again. And I discovered the double pulley was real wobley. Are these a bear to get off? Any tricks? Do I have to remove the spindle? Thanks. I'll tell ya, I don't envy you guys with larger decks. This 36" deck is heavy enough for me. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #2 Posted September 5, 2013 Take a look at the parts lists for 05-36MS01 (pulley keyed to shaft) 05-36MS02 (pulley not keyed to shaft) If you have the key it may have worn the hub making it hard to get off. You can leave the key out and use a standard nut and lockwasher. Garry Share this post Link to post Share on other sites
Lane Ranger 11,637 #3 Posted September 6, 2013 Those center pulley's have a habit of wollering out in the center on those mower decks if not installed as designed with all the original equipment. Lot of stress on the center pulley. Share this post Link to post Share on other sites
Tankman 3,523 #4 Posted September 6, 2013 For reference I usually check partstree.com http://www.partstree.com/parts/?lc=Toro+Consumer&mn=E5-48SC01 Share this post Link to post Share on other sites
Butch 194 #5 Posted September 6, 2013 I've got the parts diagram. Just taking a fast look at it tonight I was looking to see how it comes a part. Nothing stuck out to me. I'll get a better look at it tomorrow. Thanks guys! Share this post Link to post Share on other sites
