chorusguy 227 #1 Posted August 26, 2013 recently acquired a 1976 c-160. i found a c-161 and am wondering if i can interchange psrts. both are automatics Share this post Link to post Share on other sites
Sparky-(Admin) 24,647 #2 Posted August 26, 2013 They should both have the same Sundstrand hydro tranny. Mike.............. Share this post Link to post Share on other sites
chorusguy 227 #3 Posted August 26, 2013 cool. what about other parts? Share this post Link to post Share on other sites
rmaynard 16,884 #4 Posted August 26, 2013 Two different species. The C-161 has the K341AS engine, mounted in a cradle. It has a smaller oil pan than the K341S in the C-160. Because of the "shaker" cradle, a different belt guard is used, as well as different PTO components. There are other differences as well. C-161 has the gas tank under the seat, C-160 in front of the dash. Lift mechanisms are different. The dash tower is different, as the battery on the C-161 mounts where the gas tank used to be on the C-160. Many parts are interchangeable on the engines like carburetor, starter, fuel pump and covers, but the oil pans cannot be interchanged. Transmissions should be the same. 3 Share this post Link to post Share on other sites
chorusguy 227 #5 Posted August 26, 2013 thanks. they could share attahments couldnt they? Share this post Link to post Share on other sites
rmaynard 16,884 #6 Posted August 26, 2013 Yes, both are Tach-A-Matic® tractors and accessories from 1973 and later will fit. 1 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #7 Posted August 26, 2013 Good question, and GREAT answer Bob! Thank you 1 Share this post Link to post Share on other sites
wheelhorsekid 141 #8 Posted August 27, 2013 Nicely done! I too have the C 160 and C 161. Both GREAT machines. Share this post Link to post Share on other sites
Callen 64 #9 Posted August 27, 2013 The 161 has a band brake for parking, the 160 has a parking paw inside the trans axle 1 Share this post Link to post Share on other sites
SousaKerry 503 #10 Posted August 27, 2013 Some of the later C-1X0 share more parts with the newer tractors. I had a 76 C-120 that had the fender pan and support of a c-121 with a gas tank still under the hood. Seat flipped forward but the fender pan did not flip back. Share this post Link to post Share on other sites
RJR49 159 #11 Posted August 28, 2013 hydraulics are easier to access on the 160 Share this post Link to post Share on other sites
Irv 115 #12 Posted August 29, 2013 Not many psrts will fit because they are differenve! Share this post Link to post Share on other sites
chorusguy 227 #13 Posted August 29, 2013 ok. thanks everyone for the info. let me rephrase tje question a bit. obviously it would be a good thing to have a parts tractor. besides another c-160, what model would be a good candidate to have as a parts tractor? Share this post Link to post Share on other sites
rmaynard 16,884 #14 Posted August 29, 2013 (edited) If you are looking for non-engine parts for your current C-160, all of the gas powered C-series and B-series from 1974 through 1977 should be okay, with the exception of the 1974 and 75 B's which had a shorter frame. Edited August 29, 2013 by rmaynard Share this post Link to post Share on other sites
