dennist 139 #1 Posted August 20, 2013 Local CL ad C-160 $200 trans not functioning correct, engine runs fine etc. Around here that is enough info to go look anyway. I get there and it was pretty rough, told the guy no thanks and he says $150...no thanks, he says $100...obviously I had to drop the gate to the trailer....Newer 42" RD deck, rear lift and cable, dry cracked tires and plenty of oil and grease everywhere! 4 Share this post Link to post Share on other sites
Jake Kuhn 1,600 #2 Posted August 20, 2013 Wow! Nice find! If only I could stumple across one of those! lol Share this post Link to post Share on other sites
AMC RULES 37,259 #3 Posted August 20, 2013 Now that's the way you do it... get them to pay you to take it away. Nice score on that thumper. Share this post Link to post Share on other sites
squonk 47,409 #5 Posted August 20, 2013 That tractor looks a hell of a lot better than the ones around here that people want $500 and up for! Share this post Link to post Share on other sites
Wishin4a416 2,604 #6 Posted August 20, 2013 Very nice Tractor! Things must be different around your way. The deck would have brought 200 around here. 400 for what you got. I saw a horse for sale along the road on the way home today and stopped. A 200 series and the price was 250. Good Luck. Share this post Link to post Share on other sites
Road-Track 39 #8 Posted August 21, 2013 The way it should be. Two guys happy! and Wheel Horse saved from the scrap heap. Share this post Link to post Share on other sites
Trouty56 568 #9 Posted August 21, 2013 Jeez...look at just the seat!!!.....nice!!! Share this post Link to post Share on other sites
dennist 139 #10 Posted August 21, 2013 I know I got a good deal and no these deals do not come up that often around here either. I was not going to leave it even at $200, as like stated above the deck is worth $200-$250 around here also. The guy had already "spilled the beans" on the phone saying he was moving and needed it gone, so why not try to steal it, worst he could say was, "see ya!" It will be a while before I see what is really wrong with it, as I have an Onan 20 hp apart right now and a 416 with an Onan that is having its own issues. Just waiting for some free time to figure that 16hp out. Replaced all electrical components and fuel components all the reg. stuff, but still after running for a period it will run like crap, then it will not start, till cools off, then runs terrific for a period of time. It repeats over and over like this. Would a Valve seat possibly act like this? I know from what I have read it sounds electrical, but when I have done the test SOI explains well, my readings come out as they should? Share this post Link to post Share on other sites
horsesaver98 18 #11 Posted August 21, 2013 (edited) That should be your coil that is doing that or the valves and nice find I am looking for one of those but they are always over 500$ here Edited August 21, 2013 by horsesaver98 Share this post Link to post Share on other sites
Wishin4a416 2,604 #12 Posted August 21, 2013 My guess would be coil or sticky exhaust valve. Share this post Link to post Share on other sites
dennist 139 #13 Posted August 21, 2013 That should be your coil that is doing that or the valves and nice find I am looking for one of those but they are always over 500$ here My guess would be coil or sticky exhaust valve. My question would be if you have a coil that acts up when it gets hot, Will it test fine when it is cold? I have replaced with another coil and had the same exact issue, but will check with another from a verified running tractor? Share this post Link to post Share on other sites
ericj 1,580 #14 Posted August 21, 2013 check ignition module cold and hot ignition module usually goes when hot and works cold onan service manual will tell you how to check it out good luck eric j Share this post Link to post Share on other sites
leeave96 496 #15 Posted August 21, 2013 Nice looking tractor. Sheet metal looks very straight too. My guess whatever ails this tractor will be a simple fix and you got a great tractor. Good luck, Bill Share this post Link to post Share on other sites
dennist 139 #16 Posted August 21, 2013 check ignition module cold and hot ignition module usually goes when hot and works cold onan service manual will tell you how to check it out good luck eric j This would be my problem, when I tested these they were cold and they tested as the manual stated. I personally have no idea how to test the ignition module hot? I did replace with another, but also understand you can get 2 bad ones. Just wondering if there was a way to tell for sure....short of replacing from a proven running Onan engine? Share this post Link to post Share on other sites
Wheel-N-It 2,978 #17 Posted August 21, 2013 Good score on the Horse! Share this post Link to post Share on other sites
MaineDad 87 #18 Posted August 21, 2013 Man I knew you would get that being so close to you! The wiring is pretty simple on that, so give me a call if you need some help. May help to just pull the head and see what you are dealing with too. You lucky SOB Share this post Link to post Share on other sites
Tankman 3,528 #19 Posted August 21, 2013 I bet we all would've jumped on that deal. Don't see many in any condition. The looks of your "steal" appears some rather standard fixes. Good luck. PS. WHA (Wheel Horse Addiction) get you too? Share this post Link to post Share on other sites
oneroadkingman 53 #20 Posted August 21, 2013 yeah I did that once to a guy same way you did it go about an hour out there to look at the tractor and it really wasn't always he said it was for the money and pretty much played the same game you did fix it up still use it today. Share this post Link to post Share on other sites
shorts 182 #21 Posted August 21, 2013 try heating the ignition module up with a blow dryer while you have the test meter hooked up, also check the other electrical components the same way. some of the early electronic ignition stuff was sometimes heat related tempermental and would drive you to drink trying to figure it out, finally learned that a good hair drier for heat and an aerosol can of insta cold or electric kleen could help with trouble shooting. Share this post Link to post Share on other sites
BretzFamily 1 #22 Posted August 23, 2013 (edited) You said it had transmission problems. if its as heavy as.my horse. must of paid for it pushing it up on your trailer alone. Also in third picture in background in the weeds. A horse or a.newer.cookie cutter.mower looks larger Edited August 23, 2013 by BretzFamily Share this post Link to post Share on other sites
Lane Ranger 12,031 #23 Posted August 23, 2013 I think you did real well on your C-160 find. My brother David and I are putting a C160 together from TWO I purchased to make one! I paid $85 for one tractor without transmission and without rear tires. Bought it off of Ebay in Rising Sun, Indiana 20 miles west of Cincinatti, Ohio. Serial No 147441 It had a good 16 HP Kohler that has no smoke though and my brother had it running after a couple hours and a new head gasket. He says it is a 7 out 10 ! The other C 160 tractor I bought on Wednesday for $150 in Shelburn, In from another Red Square member. It had no motor but is good overall. Serial No 147221 A total of $ 235 plus gas (which of course no Wheel Horse addict, fan or buyer ever counts) for a C 160 with lots of spare parts! So $100 for a C 160 is going to be hard to beat price wise! Share this post Link to post Share on other sites
