Marv 991 #1 Posted August 20, 2013 I need dimensions on the hood insulation for the D200. This is no longer available so I need to make one. I can probably figure it out but would be helpful if someone has one with it installed. I have to find the right material to make it from too. Marvin Share this post Link to post Share on other sites
slufoot733 70 #2 Posted August 20, 2013 Marv, I own a 1978 D-200 but it has no insulation in the hood. I don't even see anything to suggest it ever did have any insulation. Are you sure the D-200 had insulation? If so maybe only certain years had it. KT Share this post Link to post Share on other sites
JamesBe1 84 #3 Posted August 20, 2013 My D-180 doesn't have any hood insluation. It's the same as a D-200 except for the bore and stroke of the engine. Share this post Link to post Share on other sites
pacer 3,177 #4 Posted August 20, 2013 This struck me as odd also - I have had a 180 from almost new and there was/isnt a hint of any insulation. Another question would be what would the insulation do? Its an open hood set-up. Marv does your tractor have the remnants of insulation on it? if so, could you take a pic of it? Or give us a description of what you have in mind. Share this post Link to post Share on other sites
bobert94 38 #5 Posted August 20, 2013 My 73 18 automatic has a clear plastic sheet glued to the inside of the hood it apears as it may have had some kind of insulation attached to the plastic as there is traces of gray residue on the plasic. the plastic sheet covers just the front half of the hood directly above the motor there is even a circular cutout in the plastic directly above where the air cleaner is. hope this helps wish i could post a pic but have camera issues. Share this post Link to post Share on other sites
JackC 617 #6 Posted August 20, 2013 I have not seen any hood insulation in the parts diagrams. Share this post Link to post Share on other sites
coldone 35 #7 Posted August 21, 2013 My D200 had the same plastic but no insulation. Share this post Link to post Share on other sites
Hodge71 690 #8 Posted August 21, 2013 (edited) They all had insulation on them from the factory. It was a foil faced grey closed cell foam pad about 1 to 1 1/4 inches thick that was attached with a large sheet of double sided tape. There was a large circle cut out for the air cleaner to fit right in it without rubbing. My 18 auto had remnants of it left but I didn't install it when I redid it last year. The purpose of the isulation was sound deadening and heat reduction. Cecil wanted the 18 Automatic designed to be "quietest Wheel Horse ever built" Edited August 21, 2013 by hodge71 Share this post Link to post Share on other sites
Marv 991 #9 Posted August 21, 2013 Thanks everybody. First I am not rhe original owner of the tractor. The question arose because there is residue of some type of adhesive in the front part of the hood and it does outline the air cleaner. Checking the Toro parts viewer for 01-20KS00 I find in the sheet metal and covers item 21 is an insulation. Looks like bobert94 description. Maybe I can guestimate it and come up with something. Marvin Share this post Link to post Share on other sites
Marv 991 #10 Posted August 21, 2013 I think I will use Duct Board to make the insulator. I will trial and error for size and fit. For those who don't know, the Duct Board I am referring to is a foil faced fiberglass material used to make air distribution ducts in heating and cooling systems. It is heat resistant so it should work in this application. Marvin Share this post Link to post Share on other sites
pfrederi 19,014 #11 Posted August 22, 2013 Eastwood and other sell some foil insulation and sound proofing material Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,760 #12 Posted August 22, 2013 The insulation is in every 18hp Auto and D-Series ipl I have looked at. Garry Share this post Link to post Share on other sites
bobert94 38 #13 Posted August 23, 2013 just looked in my partsmanual for my 18 auto part # is103086 im sure there is a nos around somewhere! lol Share this post Link to post Share on other sites
Austin860 82 #14 Posted August 25, 2013 My d180 hood had some remninents of the insulation as well! It was also in my manual. If anyone had a NOS shoot me a pm Share this post Link to post Share on other sites
