Parrothead Al 17 #1 Posted August 14, 2013 I picked up another WH, C120 looks like a 1976. It came with a rear discharge deck (Needs work). It runs but smokes. Former owner removed the governor linkage and ignition switch. K301 engine. How bad are these to rebuild? 1 Share this post Link to post Share on other sites
SousaKerry 503 #2 Posted August 14, 2013 K301 rebuilds are pretty basic just leave out the grenade gears and you'll be fine Share this post Link to post Share on other sites
Dieselcowboy 211 #3 Posted August 15, 2013 Get a Kohler engine book. It will guide you front to back on these engines. As long as you can read and follow directions your good to go with the book. Share this post Link to post Share on other sites
Austin860 82 #4 Posted August 15, 2013 I'd make sure you get the governed back in there Share this post Link to post Share on other sites
Parrothead Al 17 #5 Posted August 15, 2013 Get a Kohler engine book. It will guide you front to back on these engines. As long as you can read and follow directions your good to go with the book. That sounds like a good idea, thank you. Share this post Link to post Share on other sites
Parrothead Al 17 #6 Posted August 15, 2013 I'd make sure you get the governed back in there I did replace the governor linkage and all is well, I'm not sure why anyone would remove the linkage, however the throttle linkage was also missing and the holes were used to mount the coil. The throttle was then controlled by a rubber band tied off to the plug wire. I would assume this probably help the engine self destruct the way it has . Share this post Link to post Share on other sites
gregg'shorses 77 #7 Posted August 16, 2013 Owners manual and service manual are available to download at :http://www.kohlerengines.com/manuals/landing.htm 1 Share this post Link to post Share on other sites
