darg 7 #1 Posted August 12, 2013 Can someone please maybe tell me what type of auto trans in on this 418A ID#3118KEDI > Need a manual for complete tractor 18HP twin onan what type of oil and how many qts' oil filter# and where can I get one # for the drive belt I think you fellows for the help. Share this post Link to post Share on other sites
Jeff-C175 7,206 #2 Posted August 12, 2013 (edited) 3118KEDI Check number... not sure if first digit is correct, but if it is, it might look more like this 31-18KE01 Note that the second to last digit is probably a ZERO, not the letter D. That part number tells me your machine should be a KOHLER with an EATON tranny. Are you sure the engine is an Onan and not a Kohler Magnum 18HP twin? If it is, then it's been swapped at some point in it's life. http://www.jackssmallengines.com/Jacks-Parts-Lookup/Manufacturer/toro/4087/3603 Did you look in the 'manuals' section here on RS ? Edited August 12, 2013 by Jeffpicks Share this post Link to post Share on other sites
darg 7 #3 Posted August 12, 2013 Jeffpicks I will check the # again. It is hard to tell Share this post Link to post Share on other sites
darg 7 #4 Posted August 12, 2013 Jeffpicks. Looks like 3118KE01 20273 I do not have the engine tin. to tell the make. The guy I bought the 418 from said it was a Onan.. which is apart in a box. Everything alum. except the jugs Any series of the tammy? thanks I checked the manual section Share this post Link to post Share on other sites
Jeff-C175 7,206 #5 Posted August 12, 2013 I'm thinking these are going to be your manuals: http://www.wheelhorseforum.com/files/file/348-tractor-1987-400-series-om-pt2-810473r1pdf/ http://www.wheelhorseforum.com/files/file/1519-tractor-1987-400-series-om-wiring-pt3-810473r1pdf/ Share this post Link to post Share on other sites
dennist 139 #6 Posted August 12, 2013 Should be a Kohler twin Originally Share this post Link to post Share on other sites
GlenPettit 1,717 #7 Posted August 12, 2013 (edited) This might be a good reason to not license Lawn Mowers here: or this: . Edited August 12, 2013 by GlenPettit Share this post Link to post Share on other sites
darg 7 #8 Posted August 12, 2013 Is there any way to tell what make without the tin? Share this post Link to post Share on other sites
Jeff-C175 7,206 #9 Posted August 12, 2013 Yeah, the "K" in the model number says Kohler. That number says it's a 1987 418-A . Share this post Link to post Share on other sites
darg 7 #10 Posted August 12, 2013 Thanks Jeff , I will check out the manuals you listed Share this post Link to post Share on other sites
Jeff-C175 7,206 #11 Posted August 12, 2013 Is there any way to tell what make without the tin? I dunno... maybe look at all the parts and see if you can find some part numbers? Should be able to find the Magnum 18 manuals at the Kohler website, might be some pics you can compare parts you have? Share this post Link to post Share on other sites
dennist 139 #12 Posted August 12, 2013 Can you look at the intake and carb just compare to the Onan/Kohler? Share this post Link to post Share on other sites
darg 7 #13 Posted August 13, 2013 On carb. where the y pipe bolts up to the carb # 5205318 No K or O Any references to the #? Thanks Share this post Link to post Share on other sites
dennist 139 #14 Posted August 13, 2013 If you post a pic of the carb we should be able to help. Share this post Link to post Share on other sites
darg 7 #15 Posted August 14, 2013 Checked at parts tree site and the # 5205318 comes up as a kohlor thanks everyone for the help Share this post Link to post Share on other sites
darg 7 #16 Posted August 14, 2013 can someone give me a part # for the 400 filter? Also the parts manual for the 400 trans & the 418A parts manual thanks Share this post Link to post Share on other sites
Jeff-C175 7,206 #17 Posted August 14, 2013 (edited) Why not head on over to the manuals section and see if you can track down what you need? This is the page that comes up if you go up to the top and click on the "MANUALS" link in the bar across the top of page: http://www.wheelhorseforum.com/files/ You know the year and model number of your machine now... Or, click on that link to Jack's Small Engines that I posted in #2 and look up any part ya want? or rcpw.com or partstree.com or even toro.com ... there's any number of sites that sell parts and have illustrated parts lists. Edited August 14, 2013 by Jeffpicks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,438 #18 Posted August 14, 2013 The original engine for the tractor model number 31-18KE01 is listed as being M18QS-24510 If you go to http://www.partstree.com/parts/ and type Kohler in the 2nd box and M18-24510 in the 3rd box the illustrated parts lists will come up. Garry Share this post Link to post Share on other sites
