JamesC-120
Kohler k301 oil consumption
JamesC-120
Should a Kohler K301 use any oil at all?
illinilefttackle
Depends on its age and how it has been maintained-I completely rebuilt mine 5 years ago-and have not used any oil in between changes at all-Al
rmaynard
Many factors are involved in oil consumption. As stated, depending on the condition of the engine and how it was maintained, you could be burning oil if the rings are bad, losing oil if the seals or gaskets are bad, blowing oil out if the breather is clogged. My K241's (K301 block) don't use any oil from oil change to oil change (once per season). One engine is rebuilt, the other is 36 years old and never been rebuilt.
JamesC-120
If my engine is burning oil will it loose any power?
rmaynard
It is possible that if the rings are bad, you could loose power.
Fordiesel69
A little oil consumption is not an issue if the engine does not knock.  Certain brands of oil will "flash" off and appear to be consuming oil, when really it is just vaporizing out the breather vent.
Not need for an overhaul as long as you dont; see clouds of blue smoke.
can whlvr
i  have a 414 that uses oil,my other 414 doesnt,the one that uses oil is a little weaker but still runs great so just keep an eye on the oil level if they use oil,but as stated if theres clouds of smoke time to see whats wrong
