Charlie Smith 142 #1 Posted August 6, 2013 Hello When I got my raider 10 I got these weights with it, this was a year ago now, I just don't know where or what they would be used for for, quite confusing, I don't think there wheel horse original, there's no markings on them Share this post Link to post Share on other sites
Jrblanke 918 #2 Posted August 6, 2013 They look home made to me. The handles on the top look like pieces of a coil spring from a car. Perhaps they were set into a weight box. Share this post Link to post Share on other sites
Sparky-(Admin) 23,818 #3 Posted August 6, 2013 Were they installed on the tractor when you got it? I cant figure out just where they would mount. You could make the worlds heaviest wind chime tho! Mike....... Share this post Link to post Share on other sites
Charlie Smith 142 #4 Posted August 6, 2013 Yes I agree on the home made part, what they are made of is completely over my head.....and where they would have gone I was thinking maybe they go on the part of my raider that over hangs out the front. (see below) This is my raider with the pulley cover/nudge plate on it, This is it with the cover off, maybe they hooked on the front here Share this post Link to post Share on other sites
Dual Drive Horse 6 #5 Posted August 6, 2013 If it had the tiller fitted in the past, I have found it makes them too light on the front and difficult to turn, so assume this was an attempt to cure it. Share this post Link to post Share on other sites
groundhog47 347 #6 Posted August 6, 2013 Charlie, they look to be of some babit type metal... or are they steel. Could they be BITS from a hammer mill? Is the loop cast on or welded onto the weight? Maybe they were gate counterweights for a self closing gate and some one recycled them. Share this post Link to post Share on other sites
Tankman 3,523 #7 Posted August 7, 2013 Definitely something homemade! Looks like they were used on the front, as you noted. I used an assortment of front weights when plowing my garden years ago. Definitely need front weight when using rear implements. Now I wonder, "Why didn't I save those window sash weights? Darn!" Using bolts and auto brake drums made a few rear wheel weights sometime ago. Worked great. 2 Share this post Link to post Share on other sites
meadowfield 2,808 #8 Posted August 7, 2013 Definitely something homemade! Looks like they were used on the front, as you noted. I used an assortment of front weights when plowing my garden years ago. Definitely need front weight when using rear implements. Now I wonder, "Why didn't I save those window sash weights? Darn!" Using bolts and auto brake drums made a few rear wheel weights sometime ago. Worked great. Wheel_Weights.jpg now I'm liking that as an idea!!!! I wonder if series land rover drums would fit inside a rear rim... Share this post Link to post Share on other sites
Charlie Smith 142 #9 Posted August 7, 2013 I think it's safe to say there homemade as all the coil bits at the top are odd shapes and sizes, what they are made from/reused from is above me aha, and I just tried them on the front bracket they fit perfectly so I guess they may have been made to fit on there, and I'm liking that brake drums weights idea, real nice... Share this post Link to post Share on other sites
Lane Ranger 11,637 #10 Posted August 7, 2013 Looks like a welder or blacksmith job on the weights! Car or truck coil spring cut to fit rectangle weights that fit in the front mule drive ! Practical and useful just like all Wheel Horse tractors! Don't forget Cecil Pond and the boys at Wheel Horse thought a lot of this stuff up just like the customers started doing after they bought these garden tractors! Share this post Link to post Share on other sites
Tankman 3,523 #11 Posted August 8, 2013 Definitely something homemade! Looks like they were used on the front, as you noted. I used an assortment of front weights when plowing my garden years ago. Definitely need front weight when using rear implements. Now I wonder, "Why didn't I save those window sash weights? Darn!" Using bolts and auto brake drums made a few rear wheel weights sometime ago. Worked great. Wheel_Weights.jpg now I'm liking that as an idea!!!! I wonder if series land rover drums would fit inside a rear rim... Take a tape measure to the junque! And, don't forget Mr. Fawkes this November! Party! Share this post Link to post Share on other sites
