JamesC-120 204 #1 Posted August 5, 2013 I was wondering what size tire should be on a wheel horse wagon 1975. Thanks Share this post Link to post Share on other sites
rmaynard 16,883 #2 Posted August 5, 2013 It depends on the model. Which one are you asking about? If it's a tub style 5 cubic ft dump cart, the size is 4.80 x 8. Share this post Link to post Share on other sites
JamesC-120 204 #3 Posted August 5, 2013 (edited) It is a 4 wheeled wagon and the problem is the tires are hitting the frame when it is turned all the way. The block that is welded on to keep it from turning to far is not warn Edited August 5, 2013 by JamesC-120 Share this post Link to post Share on other sites
groundhog47 447 #4 Posted August 5, 2013 I know this isn't an answer, but you can look at the picture of some in manuals>implements>others. Unfortunately the size of tires/wheels is not listed. Share this post Link to post Share on other sites
Kelly 1,037 #5 Posted August 5, 2013 Pretty sure the 4 wheel wagon uses the same tires as the tub cart 4.80x8 see if the wheels are on backwards with the long part of the hub facing out instead of in?? 1 Share this post Link to post Share on other sites
JamesC-120 204 #6 Posted August 6, 2013 The long part is facing in but it still hits. Share this post Link to post Share on other sites
