Austin860 82 #1 Posted August 3, 2013 What do you guys suggest. Are there any screws/ bolts I should tighten? Share this post Link to post Share on other sites
Sparky-(Admin) 23,818 #2 Posted August 3, 2013 Its been awhile since I've done one but with the mower deck off you crawl under it and find the bottom of the steering box. There is a big castle type nut on the bottom, pull the pin out and tighten it. Only tighten it a wee bit, reinstall the pin and test it out. Still loose, do it again in small increments. You don't want to over tighten it! This method worked for me on both of my D series. Mike........... 1 Share this post Link to post Share on other sites
Austin860 82 #3 Posted August 3, 2013 Much tighter! Thanks mike! Share this post Link to post Share on other sites
brandonozz 168 #4 Posted August 4, 2013 Thanks for the information Mike. I was planning on doing some searching for the information as mine is a bit loose also - saved me some time! Share this post Link to post Share on other sites
pacer 3,177 #5 Posted August 4, 2013 (edited) Me too!! and I was just about to install my newly rebuilt deck. I had grumbled several times about my steering feeling like it was getting looser, but really didnt know what to look for -- or what to do. Now before I get the deck hung back I can slide under there and check it out... Just another of the MANY reasons to follow the posts regularly, little gems like this tip could slip right by a fella. THANKS! Edited August 4, 2013 by pacer Share this post Link to post Share on other sites
Rollerman 290 #6 Posted August 4, 2013 Another think to look at, D's have a bell crank between the steering box & the tie rods. They tend to get worn at the pivot. If it has a lot of slop a pack of shims from a farm supply store can be used to snug the bell crank up & this will also improve the feel of the D's steering. Share this post Link to post Share on other sites
brandonozz 168 #7 Posted August 5, 2013 While under there you may also want to check to make sure the two blots that hold the axle pivit pin secured to the frame are tight. Mine were real loose and the only way to get to the nuts was to stick my arm up where the mower deck is and reach forward. Unless you have a trailer queen expect to get greasy all the way up to the elbow! 1 Share this post Link to post Share on other sites
