bwh3200
Mower RPM slows down on its own.
bwh3200
I suspect the throttle cable is bad, i repositioned it so that it wouldn't be so tight but have the same problem. What do I do? Thanks guys! It's a 520H.
rwilson
is it the engine rpm or just the mower deck?
Jeff-C175
I don't know if it was on a 520 or not, but I think I read a post on here a short time ago mentioned something about pinching a rivet on the throttle assembly a little tighter to cure this problem... that is if it's the engine itself slowing down and not just the mower deck.
bwh3200
Its the engine rpm, i have to keep pushing the throttle back up into full rpm position. It just drifts down after a minute or so.
rwilson
Like Jeff said, There is a rivet on the throttle lever that needs pinched a little tighter. It is where it pivots on the mounting bracket.
Jeff-C175
Yep... if you type "throttle rivet" into the search box up there at the upper right, you will find that you are not alone!
HokieAg07
Either pinch the rivet with vice grips or I take the lever/cable off the tractor and peen the rivet on the bench. Works great.
