510racer
Mower deck belt tension - ?slipping
510racer
Finally got the 42" mower deck working on my 310-8 and have an issue.  When testing it out recently the blades would stop turning.  Seems the grass was high and maybe damp and/or the deck set too low and the discharge would clog.  I didn't change the spindle belt.
Is the spring loaded pulley supposed to be free? i.e. able to slide during operation?  I noticed whoever before I owned had installed a extra jam bolt to hold the sliding bar..
Or do I just need a new belt?
Thanks!
oldredrider
The slide bar should be free to move. The spring keeps tension on the belt.
It should NOT be locked down or obstructed.
groundhog47
It may be stuck in place from debris build up. Some have steel washer top and steel bushing below bar. The steel one "freezes" up a bit easier. Some have a nylon/plastic washer/bushing replacing that set up. If you've not removed deck and checked spindle bearings, it would be a good thing to check and grease them and check the pulley grooves for overload of debris and a free turning idler pulley.
Jeff-C175
Is the correct spring installed?  or has the old spring gone 'weak'?
