dstriker 2 #1 Posted August 1, 2013 I don't know what year my onan is or how to read the model/spec number My model number is p216g-I Spec number is. 10976c Serial number number is f893564666 Thanks to anbody that can help me the people on here are very knowledgeable about these mowers and motors Share this post Link to post Share on other sites
Martin 2,134 #2 Posted August 1, 2013 (edited) simple search (google) came up with a post from sparky on model/spec numbers.... heres 3 with your spec number R1-16O802 1990 316-8 Garden Tractor 8 Speed Onan P216G-I/10976C 31-16O802 1990 416-8 Garden Tractor 8 Speed Onan P216G-I/10976C 41-16OE01 1990 416-H Garden Tractor Automatic Onan P216G-I/10976C thread is here..... should be able to determine the year by using the serial number and comparing it to others close that know what year they are. more google searching with close numbers should get you there...... maybe somebody with models that use the same engine could post there serial numbers and year to get you close. Edited August 1, 2013 by Martin Share this post Link to post Share on other sites
Martin 2,134 #3 Posted August 1, 2013 just found this........... http://www.smokstak.com/forum/showthread.php?t=36264 so if we use the guide in the first line your serial number decodes as f893564666 MYYxxxxxx f= June 89= 1989 Onan serial numbers include a build date (MMYYxxxxxxx)as the first 3 or 4 numerals or in some cases a letter for the month (A=Jan, B=Feb etc)and then 2 digits for the year (MYYxxxxxx). Share this post Link to post Share on other sites
Martin 2,134 #4 Posted August 1, 2013 (edited) now if you go back to the list from sparkys post, only 1990 and 1991 models had the C at the end of the spec number...... the engine was made in 1989 and it was installed in a 1990 or 1991 tractor...... the last 6 digits ( 564666) would narrow it down further.... Edited August 1, 2013 by Martin Share this post Link to post Share on other sites
6bg6ga 272 #5 Posted April 11, 2017 Ok, I have one for you model and serial B43E- GA016/4260B H853 921992 Share this post Link to post Share on other sites
boomers_influence 106 #6 Posted April 11, 2017 6bg6ga the B 43E is listed as a STOCK engine, 16 H.P. ( not made for a specific application ) it has a 45BB crank 1 1/8" dia. X 2.74" long. it was built in aug 1985. thank you. boomer ( the used onan engine parts guy, also NOS and new ) Share this post Link to post Share on other sites
6bg6ga 272 #7 Posted April 11, 2017 (edited) Thank you. Is the 921992 the serial number? Is it electronic ignition or points? Just curious when they went to electronic. Edited April 11, 2017 by 6bg6ga redo Share this post Link to post Share on other sites
redone 45 #8 Posted January 30, 2021 Guys. I am searching for a Onan engine rebuilt kit for 20 Hp seriel Number 6883 476680 220G 10541B Rods 0.10 or 0.20 under size. pistons 0.10 under. oem gasket sets. whom would you recommend as a good parts wear house. Thanks Bill Share this post Link to post Share on other sites
onanparts.com 185 #9 Posted February 2, 2021 On 1/30/2021 at 10:56 AM, redone said: Guys. I am searching for a Onan engine rebuilt kit for 20 Hp seriel Number 6883 476680 220G 10541B Rods 0.10 or 0.20 under size. pistons 0.10 under. oem gasket sets. whom would you recommend as a good parts wear house. Thanks Bill Hi, we have .010 and .020 undersize rods in stock for your P220G here: https://onanparts.com/index.php?main_page=index&cPath=1_4&sort=20a&page=2 .010 oversize pistons here: https://onanparts.com/index.php?main_page=product_info&cPath=1_2&products_id=806 Gasket kit here: https://onanparts.com/index.php?main_page=product_info&cPath=1_7_19&products_id=6 All OEM Made in U.S.A. :) Share this post Link to post Share on other sites
