fretscha 0 #1 Posted August 20, 2008 Hello WH-Fans, Where could i find this modell of tires with the "tractor"-profile? Attached Image Share this post Link to post Share on other sites
rustbucket 4 #2 Posted August 21, 2008 the back tires look like carlisle lug or super lug i think ag tires and i think the fronts are their turf type tires Share this post Link to post Share on other sites
ol550 830 #3 Posted August 21, 2008 Cedar Rapids Tire. com B) Share this post Link to post Share on other sites
WH854 45 #4 Posted August 21, 2008 Try Here http://stores.ebay.com/Rustybores-Tire-Store Chas From Butler Pa B) Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted August 21, 2008 I'm assuming he's trying to find tires in Germany. I suggest asking an agricultural equipment dealer. Share this post Link to post Share on other sites
fretscha 0 #6 Posted August 21, 2008 I have tried to find wich in the dimensions 22/9-12 like the original tires on my 316-8 but i can Share this post Link to post Share on other sites
refracman 167 #7 Posted August 21, 2008 Over here the 23/8.50/12 and the 23/10.50/12 are common. If you do, remember that if you get a deck for it you will have to adjust it for larger than stock rear tires or go up a size with the fronts to keep the deck level. Share this post Link to post Share on other sites
fretscha 0 #8 Posted August 21, 2008 I have found 23x8,5-12 AG Tires. 23 means that the tire is 1 cm larger as the originals? And 8,5 means that it is 0,5 cm higher? Is it possible to mount this dimension without transformations at the WH? regards from Germany Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #9 Posted August 21, 2008 They would be 1 inch taller and 1/2" narrower overall and will replace your 22 X 9.00 X 12" tires perfectly. 23 X 8.50 - 12 was actually a standard size used on many Wheel Horse models. Share this post Link to post Share on other sites
fretscha 0 #10 Posted August 21, 2008 Thanks for helping me, Refracman and TT. I can get 2 Tires for 97 euro shipping inclusive. That are 144,52 $. Share this post Link to post Share on other sites
fretscha 0 #11 Posted August 22, 2008 I think i will buy this one: Look here. Share this post Link to post Share on other sites
refracman 167 #12 Posted August 22, 2008 Them will work fine. Just a thought you might want to get tubes also, as most times you will have a slow leak from them not sealing on the rims. Save yourself some frustration been there done that Share this post Link to post Share on other sites
