greybeard 0 #1 Posted July 25, 2013 I have a Wheel Horse c-101, and I am having problems with fuel leaking from the bowl. I put a new gasket in and it is still seeping. So now I don't if that is the problem or not. I need help. Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted July 25, 2013 Is the engine running OK? or are you getting black smoke? Fuel leakage from carbs is often a problem with the FLOAT, or the FLOAT NEEDLE valve. Share this post Link to post Share on other sites
diesel cowboy 263 #3 Posted July 25, 2013 You might have a pinhole in the bowl thats making it leak. Run into that from time to time on the older tractors. Hope this helps. Stewart Share this post Link to post Share on other sites
wheelhorse66 10 #4 Posted July 25, 2013 mine done the same thing and it had a small crack were the bowl meets the gasket Share this post Link to post Share on other sites
MalMac 1,333 #5 Posted July 25, 2013 Like said before, check the bowl for small pin holes by taking it off and shining a light through it. Also I have seen very small spider cracks develop around the hole on the bottom of the carb. When the bowl is off you do not see them, when you tighten it up the the pressure opens them up enough to cause a annoying leak. Share this post Link to post Share on other sites
bartl 0 #6 Posted July 26, 2013 Make sure the fiber or rubber washer/gasket at the center of the bowl is on the INSIDE, between the bowl and the carburetor body, not on the outside. Share this post Link to post Share on other sites
