greybeard 0 #1 Posted July 24, 2013 I have a wheel horse c-101 8 speed and I need to know the oil weight to use in it....I have heard 10w-30 but also have heard 30w...what do I use? Share this post Link to post Share on other sites
pfrederi 18,897 #2 Posted July 24, 2013 Straight 30 above 32 degrees. Winter use 5w-20 or 5w-30 per Kohler manual Share this post Link to post Share on other sites
Fordiesel69 271 #3 Posted July 26, 2013 SAE 30 I recommend searching for Shell T1 SAE 30 diesel rated oil. Has a few more additives to help prevent cam wear. Or a 15w-40 off the self diesel oil will have all the good additives, but the engine may use a little more. It is easier to find which is why I use it. Myth: If you use synthetic oil, you can run them longer. FALSE!!!! In the kohlers they are splash lubed and have no oil filter. By 25 hrs you will see swirls even on a good engine. So 25 HRS MAX. Share this post Link to post Share on other sites
