SolarStallion 38 #1 Posted July 23, 2013 Hi everyone, I bought a 401 at the wheel horse show in Bieglerville. I found out the hard way why it needs a weight in the front. I was going to make a steel bracket and bolt it to the pre-existing holes on the frame and mount a weight on it. I seen a similar tractor for sale on ebay and it looked like it had a bracket made for weights bolted on it. http://www.ebay.com/itm/Wheel-Horse-604-/251308753735?pt=LH_DefaultDomain_0&hash=item3a832b4347 Is this bracket available anywhere? Thanks, Steve Share this post Link to post Share on other sites
Lars 526 #2 Posted July 23, 2013 Contact Racingfool40 here in the forum and he will help you out.. Share this post Link to post Share on other sites
Jake Kuhn 1,598 #3 Posted July 23, 2013 The brackets mike makes a very nice. He might still have some reproduction weights available too. Share this post Link to post Share on other sites
SolarStallion 38 #4 Posted July 24, 2013 I made a bracket and attached a weight. I had some angle iron and a 25lb weight from the base of a floor lamp. I cut, drilled and bolted the angle iron into the existing holes on the tractor frame. I bolted the weight to the angle. Seems to work good. How does it look? Share this post Link to post Share on other sites
SolarStallion 38 #5 Posted July 24, 2013 Here are photos Share this post Link to post Share on other sites
Pullstart 68,842 #6 Posted July 24, 2013 are you a football fan? some brown and white paint could do that weight just fine Share this post Link to post Share on other sites
SolarStallion 38 #7 Posted July 24, 2013 No, that is just the way it was shaped. It actually allows the wheels to turn too. Share this post Link to post Share on other sites
