greybeard 0 #1 Posted July 21, 2013 This is my first wheel horse. I am having a charging problems and I am not sure if it is the coil, battery, or rectifier. Are there any common issues or does anybody have any suggestions on ways to figure out which one it is? I don't have a tester to test any of these. I took off the rectifier and looked at the back. The resin that covers the circuit board is yellow. Like a wood glue yellow, not brown or black. It doesn't look burnt. Can anyone help? Share this post Link to post Share on other sites
posifour11 723 #2 Posted July 21, 2013 First things first, check all your grounds. Even make sure your rectifier has good, rust free contact with the dash tower. Share this post Link to post Share on other sites
rmaynard 16,202 #3 Posted July 21, 2013 (edited) :WRS: First of all, the coil has nothing to do with charging of the battery. The charging system is comprised of a stator (alternator) under the flywheel, the regulator/rectifier, and the battery. The circuit goes from the R/R through the ignition switch and ammeter, to the battery. Any place where the wires connect can be a problem. If you don't have a wiring diagram, you can get one from the manuals section of the forum, see below. The wiring diagram that I have added shows the charging circuit highlighted in red. As was stated above, check all grounds, especially the ones from the engine to the frame. Check all wires where they connect to an item such as the R/R, the ignition switch, the ammeter, and solenoid, and the battery. All contacts must be clean and free of corrosion. The yellow stuff on the underside of the regulator is normal. Clean the three electrical contacts on the R/R and make sure that it is making good electrical (ground) contact to the frame when you reinstall it. When the engine is running, you should be getting about 14.5 volts DC from the (+) contact spade of the R/R. Edited July 22, 2013 by rmaynard Share this post Link to post Share on other sites
Lagersolut 733 #4 Posted July 24, 2013 (edited) How specifically are you checking the " grounds " , I have a good multimeter but I'm not sure I'm doing this right - I'm all back together on my ( C-101 ) tractor and also having charging issues . Bryan Edited July 24, 2013 by Golds-Red Share this post Link to post Share on other sites
Lagersolut 733 #5 Posted July 24, 2013 Never mind - found it - wire in the plastic 3 wire plug was pushing down and not on . 16 volt charge Share this post Link to post Share on other sites
Jeff-C175 7,206 #6 Posted July 25, 2013 16 Volt charge is too high... Yer gonna 'cook' that battery if it's not already. Share this post Link to post Share on other sites
rmaynard 16,202 #7 Posted July 25, 2013 Too high voltage can result from a poorly grounded regulator/rectifier. Share this post Link to post Share on other sites
Lagersolut 733 #8 Posted July 25, 2013 Went over some things today - I'm showing 14-14.5 volt charge at the battery . Share this post Link to post Share on other sites
Jeff-C175 7,206 #9 Posted July 25, 2013 Did you find something that was causing the high voltage? What you have now is perfect. Share this post Link to post Share on other sites
Lagersolut 733 #10 Posted July 26, 2013 Did you find something that was causing the high voltage? What you have now is perfect. I'm guessing ground, after reading you and maynards post, went over every last connection with a wire brush and exposed some bare metal at the grounding points -checked the continuity on the rectifier , fired it up and got those readings . Thanks for the heads up guys - - when I got that 16 volt charge after it wasn't charging ( loose wire ) yesterday thought I was good to go. Share this post Link to post Share on other sites
