bean
swap a pto from a 10hp to an 8hp kohler ?s
bean
what is needed to swap a pto setup from a magnum 10hp kohler to an magnum 8hp kohler?
I assume the only difference is the drive pulley itself, because of the shaft size differences. are the 2 different drive pulleys drilled & tapped the same for the backing plate, etc?
Don1977
You also need the one inch inside dia. PTO sleeve.
bean
Don,
thanks, I haven't taken one apart for a while, and have forgot all the parts to it.
Kelly
Only the bore for the shaft is different, all else is the same, change the pulley and the PTO sleeve and then you will need the correct top bracket for the engine for the PTO hoop
