Btrooper29 0 #1 Posted July 15, 2013 Can anyone tell me how the vacuum hoses are routed on the air cleaner sensor on a 520H? I bought one with no harness missing gauges, and generally abused. I have most of it wired, and gauges installed but I can't find a diagram for the hoses, I see one goes to the breather but not the other one or where it mounts. Thanks Share this post Link to post Share on other sites
varosd 1,185 #2 Posted July 15, 2013 https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en on my 1988 520-H, the air cleaner sensor is located on the left side tower and is part 32 on the toro website above. and Welcome!!! Share this post Link to post Share on other sites
Btrooper29 0 #3 Posted July 22, 2013 I know where the sensor is and have it wired, I don't have the vacum hoses hooked up. I know one goes to the air cleaner but I don't know where the other side routes to. Share this post Link to post Share on other sites
MalMac 1,334 #4 Posted July 22, 2013 If you mean where the hose connects to the air sensor. There is just a small round tab sticking out that it pushes on to. i replaced mine because the tab broke off. It broke flush and was difficult to find where it was even at originally. Share this post Link to post Share on other sites
Btrooper29 0 #5 Posted July 22, 2013 If I understand you MalMac There is no hose from the opposite side of the sensor? One side is marked pressure the other side vacum. Thank you for the reply Share this post Link to post Share on other sites
Kelly 1,037 #6 Posted July 23, 2013 yes only one hose from the aircleaner to the side of the switch Share this post Link to post Share on other sites
MalMac 1,334 #8 Posted July 25, 2013 Little late on this, but be careful putting the hose on the sensor. Very easy to break on the round fitting it goes on. Especially if it is the old one which will be brittle. Share this post Link to post Share on other sites
Btrooper29 0 #9 Posted July 25, 2013 Thanks MelMac, I see where a lot of guys have repaired them. I'll take special care as I have already had too many detours . Share this post Link to post Share on other sites
Kelly 1,037 #10 Posted July 25, 2013 If you do break it, it's not the end of the world, out of the 5 520's I have only one has a hose hooked to it. Share this post Link to post Share on other sites
