slammer302 2,156 #1 Posted July 15, 2013 Just got my first suburban were would i fund identification numbers Share this post Link to post Share on other sites
Jake Kuhn 1,588 #2 Posted July 15, 2013 Most suburbans serial decals are usually gone. If it is still there it would be on the frame under where the gas tank is. If you post a picture I can identify it for you. Share this post Link to post Share on other sites
CasualObserver 3,411 #3 Posted July 15, 2013 Suburban serial locations. (These are the general locations... some may vary occasionally.) 1958/59 RJ-58 - left frame rail just behind the hood. 1959 RJ-59 - As far as I know of, no one has ever documented finding one. 1960 Suburban - Stamped into the metal throttle/choke plate just under the upper screw. 1961 Suburban - early used the top section of the 1960 plate, cut off and screwed to the hood stand. 1961 Suburban - later used a decal on the right frame rail ahead of the foot peg. 1 Share this post Link to post Share on other sites
slammer302 2,156 #4 Posted July 15, 2013 I looked it over pretty well no tag or stamps anywhere Share this post Link to post Share on other sites
slammer302 2,156 #6 Posted August 22, 2013 Never found any numbers but this is what i have Sent from my DROID RAZR using Tapatalk 2 Share this post Link to post Share on other sites
CasualObserver 3,411 #7 Posted August 22, 2013 From just that image, you appear to have a 401. The hood and foot rests appear consistent with 1961. The three piece trans and lack of built-in battery box in hoodstand/frame indicate it is not a 551 Share this post Link to post Share on other sites
