Maine Tractor 3 #1 Posted July 15, 2013 Hi everyone. I picked up my first wheel horse nut roaster today. I don't know much about wheel horses and stumbled on this site in my research. I was told the tractor is either a 61 or 62. It has the curved front axel. I think its a suburban? it has a 4hp kohler k91. If anyone has any info that would be great. I will post up some pictures when I can figure out how. Thank you. Share this post Link to post Share on other sites
Maine Tractor 3 #2 Posted July 15, 2013 Had to resize so the picture might look a little weird. Share this post Link to post Share on other sites
Sparky-(Admin) 25,940 #4 Posted July 15, 2013 The hood decal makes me think its a 1961...probably a 401. I'm not good at getting my round-hood years right so hopefully someone else will chime in. Mike............ Share this post Link to post Share on other sites
dbartlett1958 99 #5 Posted July 15, 2013 Nice looking machine! Share this post Link to post Share on other sites
546cowboy 302 #6 Posted July 15, 2013 (edited) That's a nice looking Massey too. I had one of those and got rid of it. That Tecumseh ignition coil was way to expensive. That is a very nice Horse you got there. Is that original paint? Edited July 15, 2013 by 546cowboy Share this post Link to post Share on other sites
Jake Kuhn 1,600 #7 Posted July 15, 2013 Nice suburban! That is a 1961 551. It looks to have had a kohler swapped into it at some point. The 551 was the only mid engine to have the two piece transmission. Share this post Link to post Share on other sites
Maine Tractor 3 #8 Posted July 15, 2013 Thank you for the info. What would be different about the original motor? Any advantage/disadvantage to having a two peice transmission? Share this post Link to post Share on other sites
MaineDad 87 #9 Posted July 15, 2013 Welcome Maine Tractor! That's a nice looking Wheel Horse. There's a few of here in Maine if you need any help. I'm over in New Gloucester... Micah Share this post Link to post Share on other sites
Ken B 3,203 #10 Posted July 15, 2013 The two piece tranny is beefier and less prone to axle leaks. Nice score. Share this post Link to post Share on other sites
Jake Kuhn 1,600 #11 Posted July 15, 2013 As ken said. The two piece transmission is better design than the older 3 piece. The motors are changed a lot. The original engine was a lauson h55, but they are hard to find. If it were mine I would just keep the kohler on it and enjoy it. Jake Share this post Link to post Share on other sites
KC9KAS 4,746 #12 Posted July 15, 2013 Very nice looking tractors. Thanks for the photos. Share this post Link to post Share on other sites
Digger 66 3,530 #13 Posted July 15, 2013 Nice looking machine! X - 2 ^ Share this post Link to post Share on other sites
groundhog47 448 #14 Posted July 15, 2013 and ditto the aboves on the looks, I'm a beginner on recognition, just know whatever it is I like the stature and look!!! Share this post Link to post Share on other sites
Maine Tractor 3 #15 Posted July 15, 2013 Thanks everyone. Anyone know what the model number would be for the plow blade that I see on the front of them? I would love to track one down for it. Share this post Link to post Share on other sites
dennist 139 #16 Posted July 15, 2013 Nice round hood. Welcome from Central, Me Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,358 #17 Posted July 15, 2013 Garry Share this post Link to post Share on other sites
Ken B 3,203 #18 Posted July 16, 2013 Thanks everyone. Anyone know what the model number would be for the plow blade that I see on the front of them? I would love to track one down for it. I have a plow setup for your tractor. if interested send me a pm. Can't ship it though... Share this post Link to post Share on other sites
Maine Tractor 3 #19 Posted July 18, 2013 (edited) Thanks again everyone for all the response's. I finally got some time to play and check out the tractor. I took the carb off, checked the oil and adjusted the points on the motor and she started right up. Next I pulled the plug on the transmission and a bunch of water poured out at me. The boot on the shifter is ripped and almost gone, would this be how it would have gotten in? Also what do I do now? My thought was to pull the drain plug and completely drain the transmission, fill it back up, run it around a little bit, drain and fill it again. Anyone got any other thoughts on this? Also what should I use for transmission fluid? Edited July 18, 2013 by Maine Tractor Share this post Link to post Share on other sites
Digger 66 3,530 #20 Posted July 18, 2013 I would stick a blow gun in the fill hole with a rag wrapped around it to form sort of a seal & with the drain plug out blow the heck out of it . Share this post Link to post Share on other sites
Maine Tractor 3 #21 Posted July 19, 2013 What should I use for trans fluid and anyone got the part number for the boot on this tractor. Thank you. Share this post Link to post Share on other sites
